2020-02-02T03:26:26+00:00
    2020-02-04T00:54:06+00:00
    Yup same here.. Even tried the mini displayport to minidisplayport on my monitor as well and getting teh same thing.
    2020-02-03T22:39:11+00:00
    I am also having this same problem. I am using USB-C -> Displayport on my Surface Laptop 3 Intel edition to display two external monitors via MST daisy chaining.
    When I have the both monitors powered on, they become Digital Flat Panel (640x480 60Hz) in device manager and I get no display from either. However, if I turn the second display off, it detects the correct "Dell U2414H(DisplayPort) from the primary and I am able to get a desktop display "
    This worked fine until the Firmware and Drivers update this weekend. (January 2020 edition)
    Yes! Help I am having the same issue. I would definitely chalk this up to the firmware and drivers update this past weekend.
    I'd like to reiterate this issue. I have a 49" screen and this is a problem with my dock/sp7 drivers.
    2020-02-03T16:43:49+00:00
    Thanks a lot pal.
  4. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2020-02-03T15:17:52+00:00
    >Again, a quick solution/reaction by the Surface team will be appreciated.
    I'm trying to get someone to acknowledge the issue (so far unsuccessfully)
  5. Anonymous
    2020-02-03T14:52:16+00:00
    Tried, it's somehow greyed out.
    Besides, it could be that it's caused by something else (there were >10 firmware updates released a few days ago) or a combination of them.
