2020-02-02T03:26:26+00:00
    2020-02-05T03:27:47+00:00
    HI All
    I am not even remotely an expert on Windows but this is exactly what happened to me yesterday!
    It is very frustrating because I rely on my external monitor for work.
    I hope MS fix this issue quickly
    PS.  I note there is a "fix" by finding an older MSI file and installing it but this is beyond my technical abilities.!
    Rodney
  2. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2020-02-04T10:57:20+00:00
    Hope this helps others as there is still silence from Surface
    engineering/support.
    2020-02-04T03:14:48+00:00
    Here is the December 2019 bundle for Surface Pro 7. It should include the drivers
    https://download.microsoft.com/download/0/8/b/08b0f0ba-1571-41c0-9b8a-9af8a43681ae/SurfacePro7\_Win10\_18362\_19.103.34215.0.msi
    Here is the November 2019 Surface Laptop 3 Intel:
    https://download.microsoft.com/download/3/f/4/3f4f5dff-b6a9-4006-87aa-142a8e6f77cb/SurfaceLaptop3\_Win10\_18362\_19.112.27190.0.msi
    Just extract all the files with something like: msiexec /a c:\testfile.msi /qb TARGETDIR=c:\temp\test
    and then install the graphic drivers manually.
    2020-02-04T02:50:50+00:00
    Can you share a link? Thanks in advance.
  5. Anonymous
    2020-02-04T00:59:30+00:00
    Hello Barb,
    I was able to find an old msi package for the surface drivers that included 25.20.100.7101 version. After completely deleting the device from device manager and uninstalling drivers.. rebooting, then installing the 25.20.100.7101, my external monitors are working as expected..
