Does anyone know if Microsoft is looking into this? I can't believe my surface went from one of the best devices I own to **** in one update. My setup and monitors revolve around DisplayPort and it being stuck at 640x480 doesnt cut it.
2020-02-09T14:34:06+00:00 -
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2020-02-07T13:41:15+00:00 So how do you feel about 7zip?
Günter Born 49,461 Reputation points
2020-02-07T12:52:13+00:00 Thx, did a short test - I personally won't recommend that tool due to DLL hijacking vulnerabilities (although it don't use admin credentials).
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2020-02-07T10:56:22+00:00 There is a neat graphical tool (free) to extract msi's and get an older driver.
https://github.com/activescott/lessmsi
the download is at http://lessmsi.activescott.com/
2020-02-06T23:57:42+00:00 Also the snappy driver installer should work to install the old .msi driver
https://borncity.com/win/2020/02/07/surface-pro-7-laptop-3-fix-for-640-x-480-mode-update-issue/
