Right? And the dock... uses Mini DisplayPort... which is even more hilarious
2020-02-09T19:31:47+00:00 -
2020-02-09T18:45:01+00:00 Does anyone know if Microsoft is looking into this? I can't believe my surface went from one of the best devices I own to **** in one update. My setup and monitors revolve around DisplayPort and it being stuck at 640x480 doesnt cut it.
100%. I've spent a few thousand between my surface pro 7, surface dock, and monitor (purchased through microsoft).
I'd hope they were a bit more proactive about this...
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2020-02-09T16:15:56+00:00 - you could upload it to OneDrive and get a link and then paste the link in here.
2020-02-09T16:13:39+00:00 Is there a way to attach a document? The output of the dxdiag is too many characters
Barb Bowman 80,820 Reputation points MVP Volunteer Moderator2020-02-09T14:50:46+00:00 Well there is
I'd suggest you reply in that thread, but also paste the output of dxdiag in
here as a reply, maybe others can compare, etc.
