2020-02-02T03:26:26+00:00
    2020-03-11T19:50:24+00:00
    I tried the latest Intel drivers: 26.20.100.7870, and the problem still persists with my external DisplayPort MST daisy-chained monitors.
    I reverted back to the Intel drivers: 25.20.100.7101 from the October 2019 Surface Laptop 3 release, as that version works as expected.
    I finally was able to refresh my install after many attempts and it actually kind of worked.  I am now able to get 1 external monitor working again.  Not the two I originally had but better than no externals. However, I needed to disconnect the second monitor to allow the first monitor to be seen.
    I am using the Surface dock and mini-display port. The display adapter driver is the December 2019 version, 26.20.100.7641.
    Where can I find the October driver files?  I see websites talking about it but no download links.
    PS: My SP7 is saying I have additional MS updates but I'm scared to even restart the SP7 much less upgrade anything. MS has really damaged this customers confidence, not like they care.
    2020-03-07T16:44:21+00:00
    2020-03-06T10:36:36+00:00
    I have a microsoft store here but I doubt they know jack.
    They "supposedly" have a way to report issues to Surface Support/Engineering. It
    may be worth going to the Store, speaking to a manager, showing the manager
    your device AND showing them the threads here.
    2020-03-06T05:38:21+00:00
    I agree this is unacceptable, especially for a new purchase of a surface pro 7 and dock.
    Is there any way they could be financially accountable? There should be some sort of pressure to fix the issue, otherwise they will take their sweet time.
    I am not sure who is the best person to raise the issue to. I have a microsoft store here but I doubt they know jack.
  5. Anonymous
    2020-03-06T05:28:47+00:00
    The silence is getting ridiculous... At least MS can tell us they're looking for a solution and we can expect a fix in ? days/weeks.
    Right now it looks like they don't have a clue themselves.
    Cheers.
