2020-02-02T03:26:26+00:00
    2020-06-23T14:48:06+00:00
    Then I would request someone to put up step by step instruction for not so intelligent people like me to install such drivers. That would be a great help! Thanks upfront.
  2. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2020-06-23T10:47:09+00:00
    Those files are NOT redistributable. 7-zip can open and extract these msi files.
    2020-06-22T18:14:40+00:00
    Moderator Edit: Microsoft MSI files are not redistributable.
    Cheers.
    2020-06-22T12:51:39+00:00
    I dont see how I can contact to your gmail if I need the driver. Can you let me know how I can contact you?
  5. Anonymous
    2020-06-22T12:27:56+00:00
    I guess Microsoft really doesnt care about the Surface line of products..
    This should have been fixed by now. Easily been fixed.
