2020-02-02T03:26:26+00:00
  1. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2021-02-27T17:33:53+00:00
    Exchange probably won't solve the issue......
    So the older driver did not solve the problem for you at all? And you've tried a
    wipe and reimage?
    There are not a lot of people still reporting this issue so they would recommend
    an exchange if you tried a reimage and tried the officially recommended Surface
    USB-C to DisplayPort Adapter for Business and failed to resolve the problem.
    Microsoft is currently out of stock, but Amazon seems to have it
    https://www.amazon.com/Microsoft-Surface-Type-C-DisplayPort-Adapter/dp/B07G4FJTGJ/
    2021-02-27T16:28:29+00:00
    Can you get someone from Microsoft to look into this issue again?
    At this point, their advice will be to wipe and reimage with a downloadable
    recovery image and if you still have this issue to pursue an exchange.
    2021-02-26T19:02:13+00:00
    Did the recent 27.20.100.8681 driver (Intel Display, Intel Extension) fix it for you?
    This newest update broke if for me again, and I had to delete and install the old version again.
  4. Barb Bowman 80,820 Reputation points MVP Volunteer Moderator
    2021-02-26T13:14:10+00:00
  5. Anonymous
    2021-02-26T01:01:16+00:00
    Hey everyone,
    Thank you for reporting this issue, we are actively investigating. Please continue monitoring this thread for additional information and continue to check for Windows Updates.
    Thanks,
    BryanH [MSFT]
    Please we need a proper fix, please be responsible.
