2020-02-02T03:26:26+00:00
    2021-03-11T17:28:00+00:00
    As I wrote, I used the old driver, and I did exactly what you wrote.
    However, let me emphasize that it is not a solution, it is a mitigation. The driver got regression and should be fixed and this is how it should be done.
    A moment ago I contacted intel via chat and they created an internal ticket 04999879
    Not sure how seriously they would treat that issue, lets see. I guess that I am not the first one so probably it will be of low priority
    2021-03-11T16:20:39+00:00
    2021-03-11T12:27:48+00:00
    For everyone that can duplicate this, it is extremely important that you use the
    Feedback Hub App and file a problem report. DO use the "duplicate this issue"
    function. Please file the report, then SHARE the feedback, and get a LINK. Post
    the link here as a reply.
    2021-03-11T08:45:16+00:00
    I have identified a reproducible solution to this problem. The important thing is the order.
    If the error occurs on new installation or after an update, you have to install an old driver first. For me it works with version 25.20.100.7101 from 05.08.2019 This driver is included in the package SurfacePro7_Win10_18362_19.103.34215.0.msi.
    First you have to install this package. But after the installation this driver is not used yet, because Windows finds a newer driver.
    In the next step you have to uninstall the graphics card "Intel(R) Iris(R) Plus Graphics" via the device manager and also click the checkbox to remove the driver during the uninstallation. After a restart, Windows searches for a driver and automatically uses the last driver that is available. In the Device Manager, the version used is displayed for "Intel(R) Iris(R) Plus Graphics" under "Driver".
    As long as the resolution is 640x480, the device must be uninstalled again and again until the driver that was installed in the first step is displayed.
  5. Anonymous
    2021-03-11T07:47:45+00:00
    It is amazing that the issue persists for over a year and nothing can be done. I just received surface book 3, connected it to surface port (1) and dp to P3421w and has exactly the same issue.
    The only solution so far was apply some ancient intel iris plus graphic driver version 25.20.100.7101 from 8/5/2019. Why cannot MS force Intel to ship fix? It is more likely this issue.
