2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-09-27T10:26:22+00:00
    So far I still have not had a recurrence of the 75% start up issue since installing the recent Surface firmware update released through Windows Insider. This might indeed be the long awaited fix.
    Even if it is fixed. I would really like to know what the actual cause/nature of the problem was, just out of curiosity.
    2019-09-27T05:48:51+00:00
    @ Johnny W Lam
    unfortunately, the installation of the .msi file re-proposes the 103.2614.257.0 update  in question and, therefore, I have the same behavior.
    I have to wait for new firmware update!
    2019-09-26T22:30:33+00:00
    So far so good, with latest update I still get 100% on startup.
    let’s see next days
    2019-09-26T22:22:22+00:00
    @ Johnny W Lam
    I will do it, but I fear that I will find the same 103.2614.257.0 update driver that I have already updated in August and that I am convinced is responsible for the battery draining.
    Thanks again.
