2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-09-02T13:07:29+00:00
    Maybe they've already released this fix.
    I don't want to get my hopes up (nor yours) prematurely, but I haven't experienced any power loss during my last couple of shut downs, and I did install an update the other day that I believe was released on August 30th.
    2019-09-02T12:47:14+00:00
    Hi all, I've the same issue, tho it's a Surface Laptop 2. Just to update you all as kind act, I just ended a conversation with MS support and their tech guy stated that this is a problem known to them and they will release soon a fix for it.
    No specified date but "since this is a issue a lot of people is experiencing, the release will be done quite quickly"
    Crossing fingers!
    2019-09-02T08:30:28+00:00
    That's good to know!
    If the problem occurs in the replacement device I receive, I shall try the same trick.
    2019-09-02T08:26:08+00:00
    Yes I did. But no specific response to what might be causing the problem. They just said that we need to isolate the problem and that I should send the device back.
