2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-09-01T07:18:07+00:00
    No such luck for me. Guess I will continue to wait for Microsoft to put out some kind of software fix.
    2019-09-01T07:07:31+00:00
    I've done this over the past few days and can confirm it worked for me.
    I was having the issue where after closing it down at 100% it would turn on with 75%. Whether it was a few hours or days later.
    I have surface pro 6
    Basically did
    • the disable of drivers on Friday,
    • left it over night on Friday night,
    • drained it yesterday (Saturday) by streaming TV until it turned of itself,
    -recharged to 100%,
    • my battery was already set to recommended so didn't make that change.
    • Then turned it off yesterday (Saturday) afternoon.
    • Just turned it on this morning (Sunday) and still has 100%.
    Happy days
    2019-08-31T13:45:13+00:00
    Did you ask them what's the cause of the problem in the first place? If they're confident that they can send you a unit that won't have the issue, they must know what's causing it.
    2019-08-31T13:22:24+00:00
    I had a 3 hour long chat with a Microsoft agent on the Get Help app as I was having the same problem in the replacement device they sent me. And of course also in my original device which I purchased in May 2019.
    I have been told that they have a specially tested replacement device that surely does not have this battery problem which they will be sending me. I'm hoping this solves the problem. I also have an email saying that if the replacement device i get also has the problem, then they will give me a brand new device.
    Now I'm not sure what happens if the brand new device also has the problem, but I'm going ahead with this process and see where things go. I'm curious to know what Microsoft will do after they have exhausted all their options.
