2019-08-17T15:39:13+00:00
2019-10-11T17:10:26+00:00
October 10 release
379 additional answers
    2019-08-28T10:44:56+00:00
    Has anyone here been able to verify that this "fix" works? I haven't had an opportunity lately where it's been convenient to shutdown my PC for 10-12 hours, and frankly, I'd like some confirmation that this works before I even bother to try.
    I can verify that mine was fixed and working normally. Thanks for advice.
    2019-08-28T10:36:14+00:00
    Windows will automatically reinstall the drivers the next time you restart/power on your Surface
    2019-08-28T03:46:48+00:00
    The steps say to uninstall the drivers. At what point do you reinstall them, and how?
    2019-08-26T06:06:27+00:00
    I got confirmations via private message on Reddit.
    Like I said in my original post, do it at night before you go to bed :)
