Azure Percept Reference solution for Voice Control Inventory Management has errors in Azure Functions.
vinit sawant 11 Reputation points
2022-08-24T12:10:19.847+00:00
Azure Percept Reference solution for Voice Control Inventory Management has errors in Azure Funtions.
Trying out the reference solution in the below link-
https://github.com/microsoft/Azure-Percept-Reference-Solutions/tree/main/voice-control-inventory-management
documentation link :
https://learn.microsoft.com/en-us/azure/azure-percept/voice-control-your-inventory-then-visualize-with-power-bi-dashboard
Getting the following error when testing the function app at step 2->7->d. of the documentation.
Error: ****Result: Failure Exception: AttributeError: module 'azure.functions._abc' has no attribute 'SqlRow'****
The username and password given in the CRUD.py file are correct. Still the error.
ODBC Driver 17 is also installed.
Azure Percept
Azure Percept
A comprehensive Azure platform with added security for creating edge artificial intelligence solutions.
Azure Functions
Azure Functions
  1. vinit sawant 11 Reputation points
    2022-08-30T06:33:56.243+00:00
    Hello @QuantumCache ,
    That error is somehow solved, but i am getting a new error now,
    Encountering a new Error after step 2->7->d. of the documentation.
    Error: Result: Failure Exception: OperationalError: ('HYT00', '[HYT00] [Microsoft][ODBC Driver 17 for SQL Server]Login timeout expired (0) (SQLDriverConnect)')
    In the SQL db firewall setting, I have enabled " Allow Azure services and resources to access this server".
