Azure Percept Reference solution for Voice Control Inventory Management has errors in accessing the SQl database.
vinit sawant 11 Reputation points
2022-08-18T08:06:08.857+00:00
Azure Percept Reference solution for Voice Control Inventory Management has errors in accessing the SQL database.
Trying out the reference solution in the below link-
https://github.com/microsoft/Azure-Percept-Reference-Solutions/tree/main/voice-control-inventory-management
documentation link :
https://learn.microsoft.com/en-us/azure/azure-percept/voice-control-your-inventory-then-visualize-with-power-bi-dashboard
Getting the following error when testing the function app at step 2->7->d. of the documentation.
Error: ****Result: Failure Exception: ProgrammingError: ('42000', '[42000] [Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Cannot open database "Stock" requested by the login. The login failed. (4060) (SQLDriverConnect)')****
The username and password given in the CRUD.py file are correct. Still the error.
ODBC Driver 17 is also installed.
Azure Percept
Azure Percept
A comprehensive Azure platform with added security for creating edge artificial intelligence solutions.
Azure SQL Database
  1. Alberto Morillo 34,831 Reputation points MVP Volunteer Moderator
    2022-08-18T10:34:57.963+00:00
    Could please try to reset the Server admin password and then update the password on the CRUD.py file accordingly?
    On the firewall settings of the Azure SQL database:
    Please allow Azure services to access the database.
    To connect to Azure SQL Database using Power BI please consider the steps provided here.
    Hope this helps.
  2. Alberto Morillo 34,831 Reputation points MVP Volunteer Moderator
    2022-08-19T12:55:29.313+00:00
    @vinit sawant About the new error:
    Error: Result: Failure Exception: AttributeError: module 'azure.functions._abc' has no attribute 'SqlRow'
    Please try the solutions provided in GitHub.
