Complete Microsoft’s exact startup sequence on each affected Surface Laptop; if it still only flickers and goes black, submit it for warranty repair or replacement.
Four devices failing within five weeks is unusual and understandably frustrating. Similar symptoms have been publicly reported, but there is no confirmed Microsoft advisory in the available material identifying this as a widespread defect across Surface Laptop models.^1^
Complete the exact power sequence
Because “reset” can mean several different procedures, perform these steps unless your previous reset followed them exactly:
- Disconnect everything from the laptop: USB devices, external displays, SD cards, docks, and other accessories.
- Connect the power supply designed for that Surface.
- Leave it charging for at least 15 minutes.
- Close and reopen the lid, then press Power once.
- If the screen flickers but remains black, press:
Windows logo key + Ctrl + Shift + B This attempts to wake or reset the display path.
- If nothing changes, press and hold Power until the logo appears—approximately 20 seconds—then release it.
These are Microsoft’s documented steps for a Surface that does not turn on, turns off during startup, or becomes stuck on a black or logo screen.^2^
If it still fails
Microsoft’s guidance states that a Surface which remains unable to start after those steps requires a service option.^2^
For each personal device:
- Go to https://account.microsoft.com/devices.
- Sign in with the Microsoft account associated with the Surface.
- Register the device if it is not listed.
- Check its warranty status.
- Select the affected device, select Next, and follow the prompts to create a service order and shipping label.^3^
For the newly purchased unit, also ask the retailer whether it qualifies for an immediate return or exchange rather than repair.
Ask the supplier or Microsoft Support to handle the four failures as one repeated-failure incident, providing:
- Exact Surface Laptop model and serial number for each unit
- Purchase dates and supplier
- Whether they came from the same order, shipment, or batch
- Charger LED behavior
- Whether the screen flickers once or repeatedly
- The outcome of the exact sequence above
That grouping is a request for investigation, not a guaranteed Microsoft service process. If these are organization-owned devices, use the organization’s IT help desk or Surface business service channel instead of the personal-device workflow.
- How to fix surface laptop 5 that will not turn on - Microsoft Q&A
- Surface won’t turn on or start | Microsoft Support
- How to get service or repair for Surface
