Fix Printer problem not being supported by Windows
Barb Kreitzer 0 Reputation points
2026-11-12T18:01:37.7666667+00:00
error message on laptop that my HP Envy printer is not supported by Windows and is now grayed out. Plus, the Bluetooth connection to other devices no longer works, and is not available to print.
Windows for home | Windows 11 | Devices and drivers
    2026-11-12T18:03:22.5866667+00:00
    Restore the laptop’s Bluetooth hardware first because its failure across multiple devices is broader than the printer, and then remove and reinstall the grayed-out HP Envy using a Windows 11-compatible driver.
    1. Restore Bluetooth
    A missing or grayed-out Bluetooth control means Windows cannot currently detect or enable the Bluetooth hardware.
    1. Hold Shift while selecting Start → Power → Shut down.
    2. Wait one minute after the laptop switches off.
    3. Turn it back on and check Settings → Bluetooth & devices.
    Use Shut down, not Restart; this fully powers off the Bluetooth hardware.^1^
    If Bluetooth remains unavailable:
    1. Right-click Start → Device Manager.
    2. Expand Bluetooth and locate the adapter—its name may contain “Bluetooth” or “Radio.”
    3. Right-click it and select Update driver → Search automatically for drivers.
    4. Install any offered driver and restart when prompted.
    5. Open Settings → Windows Update → Advanced options → Optional updates.
    6. Install available Bluetooth, firmware, BIOS, or UEFI updates, restart, and test again.^1^
    If Windows finds no suitable driver, download the latest Windows 11 Bluetooth/wireless driver for the exact laptop model from the laptop manufacturer—not from HP’s printer site. Run its installer, or use Device Manager → Bluetooth adapter → Update driver → Browse my computer for drivers for downloaded .inf driver files.^2^
    If the Bluetooth category or adapter is completely absent even after the power-off and manufacturer driver/firmware installation, contact the laptop manufacturer; Microsoft identifies driver, firmware, or Bluetooth hardware errors as the typical causes of this state.^1^
    2. Reinstall the HP Envy printer
    After Bluetooth is restored—or immediately if the printer normally uses Wi-Fi or USB rather than Bluetooth:
    1. Open Settings → System → About and note the Windows 11 version and whether the system is 32-bit or 64-bit.
    2. Go to Settings → Bluetooth & devices → Printers & scanners.
    3. Select the grayed-out HP Envy and choose Remove.
    4. Restart the laptop.
    5. Return to Printers & scanners and select Add device beside Add a printer or scanner.
    6. Allow Windows to install its recommended driver.^3^
    If Windows still reports that the printer is unsupported, obtain the driver for the exact HP Envy model, specifically matching Windows 11 and the laptop’s system type, from HP’s support site. Install it, restart Windows, and add the printer again. Avoid drivers marked for older or unsupported Windows versions.^3^
    If Windows detects the printer but it remains unusable:
    1. Open Device Manager.
    2. Expand Printers or Print queues.
    3. Right-click the HP printer and select Update driver.
    4. If no update is found, select Uninstall device and restart; Windows will attempt to reinstall the driver automatically.^4^
    For a Wi-Fi-connected Envy, also ensure the printer and laptop are connected to the same Wi-Fi network. For USB, reconnect it directly to another laptop USB port before adding it again.^4^
    1. Windows 11
    2. Windows 11
    3. Windows 11
    4. Windows 11
  2. Neil D 34,835 Reputation points Volunteer Moderator
    2026-11-12T18:53:02.63+00:00
    The printer manufacturer is responsible for providing drivers for windows. If the printer is no longer supported in Windows 11 then there is not much can be done.
    Sometimes windows will have basic drivers that may work for some printers but not all.
    Have you checked on the HP website to see if there are any Windows 10/11 drivers?
