How to fix severe battery drainage??
Sereni 0 Reputation points
2026-11-12T00:15:28.8933333+00:00
Lately I've noticed whenever my laptop (Windows 11 Home) is unplugged, the battery starts going down about 1% per 1-5 seconds. This is really annoying as I have to keep my laptop plugged in at all times. I've checked my battery report and the design capacity and full charge capacity lines up.
I tried restarting, reinstalling/disabling my ACPI battery, changing my power plan, and basically every common fix that people said worked.
If you know what to do, then please tell me what to do and why my laptop's doing this.
Windows for home | Windows 11 | Performance and system failures
    2026-11-12T00:15:49.8933333+00:00
    Since the battery report shows design capacity and full charge capacity still line up, the battery may not be heavily worn, but the drain rate described is not normal.
    Given the steps already tried, use this path next:
    1. Run the built-in Power troubleshooter.
      Go to Start > Settings > System > Troubleshoot > Other troubleshooters, then select Run next to Power. This lets Windows automatically detect and adjust power-related settings.
    2. Check which apps are using battery in the background.
      Go to Start > Settings > System > Power & battery > Battery usage. Under Battery usage per app, look for apps using a lot of battery in the background. For apps that support it, select More options > Manage background activity, then change Let this app run in the background.
    3. Reduce sleep and power usage settings.
      Go to Start > Settings > System > Power & battery > Screen and sleep and choose a shorter time for On battery power, put my device to sleep after.
    4. Choose a more efficient power mode.
      Go to Start > Settings > System > Power & battery and set Power mode to a more efficient option if that setting is available on the PC.
    5. If video playback is involved, reduce battery use there too.
      Go to Start > Settings > Apps > Video playback. For Battery options, select Optimize for battery life and enable Play video at a lower resolution when on battery.
    6. Turn on Airplane mode when wireless connections are not needed.
      Go to Start > Settings > Network & internet and turn on Airplane mode. This reduces battery use from Wi‑Fi, Bluetooth, and other wireless radios.
    7. Use Energy recommendations.
      Go to Start > Settings > System > Power & battery > Energy recommendations, then select Apply all or adjust the listed settings individually.
    8. Check for Surface app diagnostics only if the device is a Surface.
      In the Surface app, expand Help & support, check update status, install available updates, then use Get help to detect issues.
    Why this can happen:
    • A background app may be consuming large amounts of power even if battery health looks normal.
    • Wireless radios, video playback settings, or inefficient power settings can sharply increase drain.
    • Heat can also accelerate battery deterioration over time, even when current capacity still appears normal.
    If the battery is also draining rapidly while the laptop is shut down, one accepted Microsoft Q&A explanation is that the PC may be entering a low-power sleep state instead of fully shutting down.
    If the battery ever becomes visibly swollen, stop using the device immediately.
  2. Clary-N 19,130 Reputation points Microsoft External Staff Moderator
    2026-11-12T05:38:14.61+00:00
    Hi Sereni,
    Thanks for confirming what you’ve already tried. Since the battery is losing charge so quickly, I’d like to narrow down whether this is happening only in Windows or whether it may be a hardware or firmware issue.
    Could you share the laptop’s exact make and model, along with the Windows version shown when you type winver into Search? Also, does the battery percentage decrease steadily or does it suddenly jump down by several percent? Does the laptop become unusually warm when this happens?
    As a further check, please install the latest BIOS, chipset, graphics and power-management updates from the laptop manufacturer’s support page. Reinstalling the ACPI battery device does not update those underlying components.
    You can also charge the laptop fully, unplug it, restart into the BIOS/UEFI screen and leave it there for about 10–15 minutes. If the battery continues dropping rapidly while Windows is not running, that would point more toward the battery, charging circuitry or another hardware issue. In that case, I’d recommend contacting the laptop manufacturer for a battery and power-system diagnostic.
    Please let me know what you observe during that test.
