In the application’s print window, clear Print to file and select your physical printer instead of Microsoft Print to PDF, Microsoft XPS Document Writer, or another virtual printer.^1^
Turn off “Print to file”
- Open the document and select File > Print.
- Under Printer, select your actual printer.
- Clear the Print to file checkbox if it appears.
- Confirm that the selected printer shows Ready, then select Print.
If it still asks for a filename
The printer itself may be assigned to the Print to File port:
- Close any applications from which you were printing.
- Select Start, type Control Panel, and open it.
- Set View by to Large icons or Small icons.
- Open Devices and Printers.
- Right-click your physical printer and select Printer properties.
- Open the Ports tab.
- If FILE: (Print to File) is selected, change it to the printer’s actual port. The matching Q&A guidance identifies LPT1 for a USB-connected printer or WSD for a wireless printer.^2^
- Select Apply > OK.
Only change the port if it is currently set to FILE:. If several other ports are listed and the correct one is unclear, reinstalling the manufacturer’s driver is safer than guessing.
Test the printer
Go to Start > Settings > Devices > Printers & scanners, select the printer, and then choose Manage > Printer properties > Print Test Page.^1^
If the test page also fails, uninstall the printer, restart Windows, and reinstall the correct Windows 10 driver supplied by the printer manufacturer.^3^
