Touchpad and mouse issues
Melanie Smith 0 Reputation points
2026-11-08T17:59:04.88+00:00
My cursor does not show on the screen. My touchpad does not work. How can I fix them? How can I update the drivers also.
Windows for home | Windows 11 | Devices and drivers
    2026-11-08T17:59:42.6833333+00:00
    First, press the keyboard key showing a touchpad icon—usually one of F1–F12, sometimes requiring Fn + that key—because the touchpad may simply be disabled.^1^
    1. Restore pointer control
    1. Press the touchpad function key once, wait a few seconds, and move a finger across the touchpad.
    2. If you have a USB mouse:
      • Connect it directly to a different USB port, not through a hub.
      • For a wireless mouse, replace or charge its battery, then unplug its receiver for about 10 seconds and reconnect it.
      • If possible, test the mouse on another computer. If it also fails there, the mouse may need replacement.^2^
    Windows can be navigated without a pointer: use Tab to move between controls, arrow keys to select, Enter to open, and Spacebar to toggle checkboxes.
    2. Install driver updates through Windows Update
    Windows Update is Microsoft’s recommended method for updating touchpad drivers.^3^
    1. Press Windows + I.
    2. Select Windows Update → Advanced options.
    3. Under Additional options, open Optional updates.
    4. Open Driver updates, select any touchpad, mouse, HID, chipset, or input-device update, and choose Download and install.
    5. Restart the computer even if Windows does not request it.
    Optional driver updates are not installed automatically, so this section must be checked manually.^4^
    3. Reinstall the touchpad driver
    If updating does not restore it:
    1. Press Windows + X, then choose Device Manager.
    2. Check both:
      • Human Interface Devices
      • Mice and other pointing devices
    3. Select the touchpad entry. It may include a manufacturer name such as Synaptics or ELAN.
    4. Open it with Shift + F10, select Uninstall device, and confirm.
    5. Restart Windows. Windows will attempt to reinstall the driver automatically.^5^
    Do not uninstall an entry unless it is clearly the touchpad or pointing device; removing unrelated HID entries can temporarily disable other input devices.
    4. If the touchpad is missing from Device Manager
    Obtain the drivers from the laptop manufacturer’s official support site using the exact model number:
    1. Press Windows + R, enter msinfo32, and press Enter.
    2. Note System Manufacturer and System Model.
    3. On another device if necessary, download the Windows 11 drivers for that exact model.
    4. Install the chipset or Serial I/O driver first, restart, and check Device Manager again.
    5. Install the manufacturer’s touchpad driver, then restart again.
    A missing touchpad entry can require the chipset/Serial I/O driver before Windows can detect the touchpad hardware.^6^ Use only Microsoft or the device manufacturer’s official site for drivers; avoid third-party driver-download utilities.^5^
    If the touchpad remains absent after the correct chipset and touchpad packages are installed, contact the laptop manufacturer for hardware diagnostics.^3^
    1. How can I fix a mousepad that is not working/responding to my touch? - Microsoft Q&A
    2. Mouse and keyboard problems in Windows | Microsoft Support
    3. Fix touchpad problems in Windows | Microsoft Support
    4. Windows 11
    5. Update drivers through Device Manager in Windows | Microsoft Support
    6. Touchpad is recognized as mouse windows 11 - Microsoft Q&A
  2. DaveM121 947.9K Reputation points Independent Advisor
    2026-11-08T18:34:36.1233333+00:00
    Hi Melanie,
    1
    Look at the Function Keys (F1 - F12) on your keyboard.
    If one of those keys has an icon representing a touchpad try pressing that key or Fn + that key to try to enable the touchpad on your laptop.
    2
    If that was not the problem, you will need to go to the support page for your laptop on the manufacturers website to download and reinstall the version of chipset drivers and touchpad drivers they provide for your laptop model.
    If you have any difficulty locating that support page, click your Start Button, then just type msinfo and press Enter, please provide a screenshot of the resulting System Information window.
  3. Emma1-N 15,005 Reputation points Microsoft External Staff Moderator
    2026-11-11T04:09:53.1833333+00:00
    Welcome Melanie Smith,
    Thanks for reaching out to Microsoft Q&A Forum. I understand that your mouse cursor isn't showing on the screen and your touchpad isn't working on your Windows 11 device, and you'd like to fix this and update your drivers.
    To narrow this down, could you please share:
    • When did this start? For example, did it begin after a Windows update, a driver install or a BIOS update?
    • Is the cursor also missing when you connect an external mouse, or is it only the touchpad that doesn't respond?
    In the meantime, you can try these steps:
    1, Check the touchpad switch in Settings and reset it
    • Press Windows + I, type Touchpad in the search box and press Enter.
    • Make sure the Touchpad switch is On.
    • Expand the Touchpad section and make sure Leave touchpad on when a mouse is connected is checked.
    • In the same section, select Reset next to Reset touchpad settings and gestures to default.
    2, Do a full shutdown
    • Press Windows + R, type shutdown /s /t 0 and press Enter.
    • After the device turns off, unplug the charger and wait about 30 seconds. Then plug it back in and turn the device on.
    3, Roll back the touchpad driver if the issue started after an update
    • Press Windows + X, then choose Device Manager.
    • Select the touchpad entry, then press Alt + Enter to open Properties.
    • Press Ctrl + Tab to go to the Driver tab, select Roll Back Driver if it's available, then restart.
    Looking forward to your update.
