Flex Consumption scales beyond maximumInstanceCount (31 instances with a limit of 20)
Lars Holm 10 Reputation points
2026-11-04T07:09:29.4466667+00:00
We run an HTTP-triggered Node.js app on the Flex Consumption plan in Sweden Central. functionAppConfig.scaleAndConcurrency is set to maximumInstanceCount: 20, instanceMemoryMB: 2048 and HTTP perInstanceConcurrency: 50. Under a load test of about 500 requests per second the app ran more instances than the limit:
  • Application Insights showed 28-31 distinct cloud_RoleInstance values per minute for five minutes.
  • OnDemandFunctionExecutionUnits reached 3,170 GB-s per minute, while 20 x 2 GB x 60 s = 2,400.
  • The InstanceCount platform metric (Maximum, 1-minute grain) showed 1 for the whole period.
An earlier test with maximumInstanceCount: 10 (512 MB) gave 41 instances and up to 515 GB-s per minute (limit 300). A control test with maximumInstanceCount: 1 was respected (1-2 instances).
The site also reports a legacy siteConfig.functionAppScaleLimit of 100. Setting it to 20 is rejected: "The following site configuration property (Site.SiteConfig.FunctionAppScaleLimit) for Flex Consumption sites is invalid."
Questions:
  1. Is maximumInstanceCount a hard limit on Flex Consumption, or can the platform briefly exceed it (for example during scale-out or when replacing instances)?
  2. Can the legacy functionAppScaleLimit value influence Flex Consumption scaling, and how can it be removed?
  3. Why does the InstanceCount metric show 1 when Application Insights and the billed execution units show many more instances?
Azure Functions
Azure Functions
  1. Lars Holm 10 Reputation points
    2026-11-04T09:44:39.6966667+00:00
    Thanks for the checklist. I went through it:
    Scope. The limit was read from the running resource (functionAppConfig.scaleAndConcurrency): maximumInstanceCount 10 with 512 MB during the first test and 20 with 2048 MB during the second. The activity log shows no writes to the app between setting each value and the end of each test. The Application Insights resource receives telemetry from this one function app only: every row during both tests has the same cloud_RoleName. There are no deployment slots (Flex Consumption doesn’t support them).
    Instances. Filtered on that cloud_RoleName:
    • Test 1 (2 Nov, 18:44–18:52 UTC, limit 10): 42 distinct cloud_RoleInstance values. 41 of them executed our HTTP functions; the last one only sent host telemetry for one minute.
    • Test 2 (3 Nov, 21:14–21:21 UTC, limit 20): 31 distinct instances, all 31 executed the HTTP functions.
    • The app’s only non-HTTP function (a nightly timer) did not run on any of them.
    Counted with customMetrics | where name endswith ' Count' | summarize instances=dcount(cloud_RoleInstance) by name and union customMetrics, performanceCounters, traces | summarize dcount(cloud_RoleInstance) by bin(timestamp, 1m). I can share the instance IDs privately.
    Billing. The platform metric OnDemandFunctionExecutionUnits also exceeds what the limit allows: up to 3,170 GB-s per minute in test 2, where 20 instances × 2 GB × 60 s = 2,400, and up to 515 GB-s per minute in test 1, where the maximum is 300. That metric is metered by the platform, not by our telemetry, so the gap can’t be explained by the telemetry scope.
    We don’t have a paid support plan, so I can’t open a technical case. Could you forward this to the Azure Functions product group? A billing case about the charges is already open.
  2. Eber Daniel Perez 165 Reputation points
    2026-11-04T21:37:26.7933333+00:00
    Hi Lars, nice troubleshooting.
    Per the docs, maximumInstanceCount is a hard ceiling for on-demand instances, but it applies per scaling group, not to the whole app. HTTP triggers share one "http" group, and each non-HTTP function (like your timer) scales on its own. Always ready instances don't count toward that limit either.
    So if only HTTP functions were running and alwaysReady is empty, 31 instances with a limit of 20 is not expected. You can check it with: az functionapp show -g <rg> -n <app> --query "properties.functionAppConfig.scaleAndConcurrency"
    About functionAppScaleLimit: on Flex Consumption it was renamed to maximumInstanceCount, that's why it gets rejected.
    If the config looks clean, I'd go ahead with the ticket and include the UTC time windows, region, resource ID and your OnDemandFunctionExecutionUnits numbers.
    Docs: https://learn.microsoft.com/azure/azure-functions/flex-consumption-plan#maximum-instance-count-the-ceiling
