Control Panel Programs and Features does not list an installed program. The program is Google Chrome
janeintoronto 0 Reputation points
2026-11-02T20:02:23.4333333+00:00
I am considering uninstalling Google Chrome. It uses a lot of memory and I rarely use it. It is listed in Programs x86. However, when I go to Control Panel Programs and Features, where users can uninstall programs, I do not see either the name "Google" or "Chrome". So how can I safely uninstall it?
Windows for home | Other | Apps
    2026-11-02T20:03:10.3266667+00:00
    Uninstall Chrome through Windows Settings rather than deleting its folder from Program Files (x86); Programs and Features is only one of several Windows uninstall locations.
    Uninstall through Settings
    Close Chrome first, then use the path matching your Windows version:
    • Windows 11: Start → Settings → Apps → Installed apps
    • Windows 10: Start → Settings → Apps → Apps & features
    Search for Google Chrome, select it, and choose Uninstall. Confirm the prompt and follow the on-screen instructions. This is the uninstall method documented by both Microsoft and Google.^1^^2^
    If Chrome is absent there:
    1. Open Start → All apps.
    2. Find and right-click Google Chrome.
    3. Select Uninstall.^1^
    Afterward, restart Windows and check that Chrome no longer opens and no longer appears under Installed apps.
    If Chrome is missing from every uninstall list
    Do not simply delete the Chrome directory. That can leave shortcuts, update components, and uninstall-registration data behind.
    • On Windows 10: Run Microsoft’s Program Install and Uninstall troubleshooter. Choose Uninstalling, then select Chrome if offered. The tool is designed to repair corrupted registry keys and incomplete uninstall information that can prevent a desktop program from appearing or being removed through Programs and Features.^3^ If Chrome is not listed, the troubleshooter may request its MSI product code. Obtaining that code requires an MSI-reading tool and is generally an IT-level procedure.^3^
    • On Windows 11: Microsoft’s current recovery guidance is to try uninstalling from Settings → Apps → Installed apps and follow any Windows troubleshooter offered after a removal failure.^3^ If Chrome remains absent, use Google Chrome support rather than a third-party “force uninstaller”; Google’s official uninstall page does not document a separate manual-removal procedure for this situation.^2^
    Removing Chrome is reasonable if it is rarely used; it is not a protected Windows component and can be uninstalled like other third-party browsers.^4^
    1. Uninstall or remove apps and programs in Windows | Microsoft Support
    2. Uninstall Google Chrome
    3. [Windows 10](https://support.microsoft.com/windows/deployment/install-upgrade/fix-problems-that-block-programs-from-being-installed-or-removed)
    4. Which browers should I use and the ones to delete - Microsoft Q&A
  2. Ramesh 183.6K Reputation points Volunteer Moderator
    2026-11-02T20:22:09.2366667+00:00
    Looks like you have Google Chrome (32-bit version) installed.
    Please reinstall it by downloading the setup program from the Google link below.
    ChromeSetup.exe
    Once installed, it should create an entry in Settings → Apps from where you can uninstall it cleanly.
