how to fix my bluetooth problem in my pc
Anmol Aman 10 Reputation points
2026-10-29T11:00:37.6666667+00:00
first of all i want ask if i on my bluetooth on pc it does not show available devices and also i reset the bluetooth but also it does not show avaiable devices
Windows for home | Other | Devices and drivers
    2026-10-29T11:01:03.1166667+00:00
    Try these steps in order:
    1. Check that Bluetooth is actually on
      • In Windows 10: Start > Settings > Devices > Bluetooth & other devices and make sure Bluetooth is turned on.
      • Also check the taskbar Action Center and turn on Bluetooth there if needed.
      • In Windows 11: open Quick settings from the taskbar or go to Settings > Bluetooth & devices and confirm Bluetooth is on.
    2. Check the device being paired
      • Make sure the Bluetooth device is powered on.
      • Charge it or replace its batteries.
      • Turn the device off, wait a few seconds, then turn it back on.
      • Keep it close to the PC.
      • If it is near a USB 3.0 device, move it farther away because unshielded USB devices can interfere with Bluetooth.
    3. Make sure the device is in pairing/discovery mode
      • If the PC does not show available devices, the Bluetooth device may not be discoverable.
      • Turn on the device’s pairing mode. For supported devices, Swift Pair can help when the device is nearby and in pairing mode.
    4. Run the Bluetooth troubleshooter
      • In Windows 11: Settings > System > Troubleshoot > Other troubleshooters > Bluetooth > Run.
      • On supported systems, the Get Help app can also run automated Bluetooth diagnostics.
    5. Update the Bluetooth driver
      • Open Device Manager.
      • Expand Bluetooth and find the Bluetooth adapter.
      • Right-click it and select Update driver.
      • Choose Search automatically for drivers.
      • If the PC manufacturer provides a newer Bluetooth driver, download and install it from the manufacturer’s support site.
      • Restart the PC if prompted.
    6. Uninstall and reinstall the Bluetooth adapter
      • Expand Bluetooth.
      • Right-click the Bluetooth adapter and select Uninstall device.
      • Shut down the PC, wait a few seconds, then turn it back on.
      • Windows will try to reinstall the driver automatically.
      • If it does not, open Device Manager and select Action > Scan for hardware changes.
    7. Check Airplane mode
      • In Windows 11, press Windows + A and make sure Airplane mode is off.
    8. Install optional firmware or system updates
      • In Windows 11: Start > Settings > Windows Update > Advanced options > Optional updates.
      • Install any available optional updates, then restart.
      • If none are available, check the PC manufacturer’s support site for BIOS, UEFI, or firmware updates.
    9. If Bluetooth is missing or grayed out
      • This can be caused by driver or firmware problems.
      • First do a full shut down, not restart: hold Shift and select Start > Power > Shut down, wait 1 minute, then power the PC back on.
    If Bluetooth still turns on but no devices appear after these steps, the most likely next area to check is the PC manufacturer’s Bluetooth driver or firmware for that specific model.
    20+ people found this answer helpful.
  2. Vikki-T 14,115 Reputation points Microsoft External Staff Moderator
    2026-10-30T07:29:50.1033333+00:00
    Hello Anmol Aman,
    Since you have already reset Bluetooth, could you please confirm whether the PC fails to detect all Bluetooth devices or only one particular device?
    If you are using Windows 11, please go to Settings > Bluetooth & devices > Devices, then under Device settings, change Bluetooth devices discovery to Advanced and try scanning again.
    Please also try pairing the device with a phone or another computer. If it appears there but no Bluetooth devices appear on your PC, open Device Manager > Bluetooth and let me know the name of the Bluetooth adapter and whether it has a warning symbol.
    Please share your Windows version, PC make/model, and the type of Bluetooth device you are trying to connect. This information will help narrow down whether the issue is with the accessory or the PC’s Bluetooth adapter.
    You can also refer to Microsoft’s official guidance here: Fix Bluetooth problems in Windows Thank you so much for your understanding.
    7 people found this answer helpful.
  3. Israel Ampadu 0 Reputation points
    2026-11-07T18:41:35.1866667+00:00
    My pc cannot connect to my phone through Bluetooth
