Help me create a Excel spreadsheet
Susan Lawrence 0 Reputation points
2026-10-17T18:08:37.7233333+00:00
I am unable to open a new excel spreadsheet. I have several active spreadsheets. I know excel is working
Microsoft 365 and Office | Excel | For home | Other
    2026-10-17T18:11:22.66+00:00
    Start Excel in Safe Mode and test File > New > Blank workbook there; if it works, disable the conflicting Excel or COM add-in.
    1. Test Excel in Safe Mode
    Because Ctrl+N and File > New already do nothing in normal mode, use Safe Mode to bypass Excel add-ins, startup files, and customized settings.
    1. Save changes in every open workbook, then close all Excel windows.
    2. Press Windows key + R.
    3. Enter:
         excel /safe
    4. Select OK.
    5. Confirm the title bar says Microsoft Excel (Safe Mode).
    6. Select File > New > Blank workbook.
    Safe Mode bypasses Excel add-ins, most COM add-ins, startup folders, and certain customizations that can interfere with Excel commands.^1^
    2. If a blank workbook opens in Safe Mode
    An add-in or startup customization is interfering with Excel. Disable add-ins and identify which one causes the problem:
    1. In Excel, select File > Options > Add-ins.
    2. At the bottom, set Manage to COM Add-ins, then select Go.
    3. Clear all checked add-ins and select OK.
    4. Close Excel and reopen it normally.
    5. Test File > New > Blank workbook.
    6. If it now works, re-enable add-ins one at a time, restarting Excel and testing after each one. Leave the add-in that reproduces the problem disabled, or obtain an updated version.
    7. Repeat the process with Manage > Excel Add-ins if necessary.
    Microsoft specifically recommends disabling add-ins individually after a successful Safe Mode test.^2^
    3. If it still fails in Safe Mode
    Repair Microsoft 365:
    • Windows 11: Right-click Start > Installed apps.
    • Windows 10: Right-click Start > Apps and Features.
    • Find Microsoft 365 or Office, select the three dots if shown, and choose Modify.
    • Run Quick Repair first.
    • Restart Excel and test creating a blank workbook.
    • If it still fails, return to the same location and run Online Repair. This is more comprehensive and may require an internet connection and subsequent sign-in.
    Repair applies to the entire Office suite, even when only Excel is affected.^3^
    Avoid deleting Excel registry keys manually at this stage; incorrect registry changes can cause additional problems.
    1. Excel not responding, hangs, freezes or stops working | Microsoft Support
    2. I get a "stopped working" error when I start Office applications on my PC | Microsoft Support
    3. Repair an Office application | Microsoft Support
  2. Dio Xavier 298.5K Reputation points Volunteer Moderator
    2026-10-17T18:34:41.13+00:00
    Welcome to the Microsoft 365 and Office Community.
    Good afternoon. What error message appears when you try to create a new Excel table? Which operating system are you using?
    Looking forward to your reply...
  3. Bulldog 5,530 Reputation points
    2026-10-17T19:42:02.21+00:00
    "I am unable to open a new Excel spreadsheet."
    Here's how to open a new Excel spreadsheet.
    1- Launch Excel
    2- Click on New
    Screenshot 2026-10-17 153412
    If you are already in an existing spreadsheet:
    3- Click on File
    Screenshot 2026-10-17 153922
    4- Then click on New
    Screenshot 2026-10-17 153652
