How to use SQL Data Reader
Corey Fleig 595 Reputation points
2026-10-17T00:52:51.2433333+00:00
I'd like to perform a select that returns 3 rows, each row with a code, and then use a sql data reader in C#. Do you have a snippet that does that? Im not sure how to submit my code example without this app blowing up on me! I'm using VS 2022, and a console app, with Microsoft.Data.SqlClient 5.1.3 or something around that version.
Developer technologies | C#
An object-oriented and type-safe programming language that has its roots in the C family of languages and includes support for component-oriented programming.
Marcin Policht 113.2K Reputation points MVP Volunteer Moderator
2026-10-17T03:20:38.21+00:00
Yep - with Microsoft.Data.SqlClient in a Visual Studio 2022 C# console application, you can execute a SELECT query that returns three rows and use SqlDataReader to read each row individually. You do not need to know the number of rows in advance; reader.Read() advances to the next row and returns false when there are no more rows.
Try the following:
using Microsoft.Data.SqlClient;
using System;
class Program
    static void Main()
        string connectionString =
            "Server=YOUR_SERVER;Database=YOUR_DATABASE;" +
            "Integrated Security=True;TrustServerCertificate=True;";
        string sql = @"
            SELECT Code
            FROM (VALUES
                ('ABC'),
                ('DEF'),
                ('GHI')
            ) AS Codes(Code);";
        using SqlConnection connection =
            new SqlConnection(connectionString);
        using SqlCommand command =
            new SqlCommand(sql, connection);
        connection.Open();
        using SqlDataReader reader = command.ExecuteReader();
        while (reader.Read())
            string code = reader.GetString(0);
            Console.WriteLine(code);
The output should be:
ABC
DEF
GHI
In this example, the VALUES clause creates three sample rows, each containing one code. Replace that query with your actual SELECT statement and update the connection string to match your environment. reader.GetString(0) retrieves the first column, using a zero-based column index. If your column can contain NULL, check reader.IsDBNull(0) before calling GetString(0).
hth
Marcin
Nguyen Dam (WICLOUD CORPORATION) 1,335 Reputation points Microsoft External Staff Moderator
2026-10-19T03:52:04.57+00:00
Hi @Corey Fleig , thank you for your question.
I have at least 2 interpretations of what you mean by "each row with a code" here: you want 3 query commands each returning a row; or you want the rows to return one additional column value, a "code".
In either case, you simply want to import the Microsoft.Data.SqlClient library and use its SqlDataReader class to declare a reader object. You can first establish and open your connection, for example:
string connectionString = "your connection string";
using SqlConnection connection = new(connectionString);
connection.Open();
Then use either of the following examples:
string[] queries =
    "SELECT 'ABC' AS Code;",
    "SELECT 'DEF' AS Code;",
    "SELECT 'XYZ' AS Code;"
foreach (string query in queries)
    using SqlCommand command = new(query, connection);
        string code = reader.GetString(reader.GetOrdinal("Code"));
(if you mean "3 query commands, each returning a row")
string query = """
    SELECT Code
    FROM (VALUES
        ('ABC'),
        ('DEF'),
        ('XYZ')
    ) AS Codes(Code);
(if you mean "one query returns 3 rows, each with a code")
Please let me know if this is what you need or clarify more information otherwise so I can better help you. Also, feel free to ask if you have any further question.
If my response provides you what you need, I would greatly appreciate it if you could follow this guide for your confirmation. Thank you.
1 additional answer
    2026-10-17T00:53:29.1733333+00:00
    Use SqlCommand.ExecuteReader() and call Read() in a loop; each successful call advances the SqlDataReader to the next returned row.^1^
        "Server=YOUR_SERVER;Database=YOUR_DATABASE;Integrated Security=True;TrustServerCertificate=True;";
    const string sql = """
        SELECT TOP (3) Code
        FROM dbo.YourTable
        ORDER BY Code;
    using var connection = new SqlConnection(connectionString);
    using var command = new SqlCommand(sql, connection);
    connection.Open();
    using var reader = command.ExecuteReader();
    Replace:
    • YOUR_SERVER and YOUR_DATABASE with your SQL Server details.
    • dbo.YourTable with the table name.
    • Code with the actual column name.
    • The connection string with your authentication settings if you are not using Windows authentication.
    GetString(0) means “read the first selected column as a string.” If Code is an integer, use reader.GetInt32(0) instead. Typed accessors reduce unnecessary type conversion.^1^
    The reader starts before the first row, so Read() must be called before accessing column values. It returns false when there are no more rows.^2^
    The using declarations dispose the reader, command, and connection even if an exception occurs. Do not execute another command on the same connection while this reader remains open; the connection is occupied by that reader until it is closed.^1^
    For posting C# in Q&A, place three backticks followed by csharp before the code and three backticks after it, as shown above.
    1. Retrieve data by a DataReader
    2. SqlDataReader.Read Method-Definition
