Edge TTS No audio received Vietnamese
Nguyễn Minh Thành 20 Reputation points
2026-10-09T08:50:41.6233333+00:00
I have try many time but there are no response audio with vietnamese
Microsoft Edge | Audio and video playback | Windows 11
Emma1-N 14,925 Reputation points Microsoft External Staff Moderator
2026-10-10T02:59:29.0933333+00:00
Welcome Nguyễn Minh Thành,
I understand that Microsoft Edge Text-to-Speech/Read aloud is not producing audio when you try to read Vietnamese content.
Could you please confirm whether “Read aloud” works normally with English or another language, and whether the issue occurs on all Vietnamese webpages or only one particular page?
Meanwhile, please try these checks:
  • Open a Vietnamese webpage in Edge, start Read aloud, then open Voice options and try another available voice. Edge allows you to change the reader's voice and reading speed.
  • Try Read aloud on a different Vietnamese webpage. You can start it using Ctrl + Shift + U.
  • In Windows, open Settings > Time & language > Language & region” and check whether Vietnamese is installed. If available for the language, make sure the Text-to-speech language feature is installed.
Looking forward to your update.
