SQL Server: Index creation and conversion issues with columnstore indexes — Encountering internal query processor errors
Nacho Cotanda Portoles 0 Reputation points
2026-10-07T14:22:11.1166667+00:00
Problem description
I am experiencing issues when creating or converting indexes on a table with existing data in SQL Server running on an Azure VM. Specifically, when I attempt to create or modify clustered columnstore indexes with options like DATA_COMPRESSION = COLUMNSTORE or changing to a clustered index with DROP_EXISTING and DATA_COMPRESSION = PAGE, the operation fails in many cases. The error returned is an internal query processor error: "The query processor could not obtain access to a required interface." The failure occurs both when creating the index from scratch and during conversions involving DROP_EXISTING. I have tried recreating the table with minimal data, and the issue persists even with a single row. The environment is SQL Server 2022, but the issue also occurs in SQL Server 2025. I have also checked for any related memory or DOP warnings, but none are reported. The table in question has no constraints or duplicates, and the process fails during index operations on a table with data, regardless of the data size.
Environment
The affected environment is SQL Server on a Windows virtual machine in Azure. The table is named [dbo].[table], and the server is running SQL Server 2022 or 2025 with the specified build. The issue occurs when creating or altering indexes on this table with existing data.
What I've already tried
I have attempted recreating the table with a small number of rows and reproducing the issue. The problem occurs even with a single row. I have not observed any SQL Server or Windows Event Viewer errors related to memory or tempdb during index creation. I also performed a backup and restore to test with a clean environment. No constraints or dependencies are involved, and the table's structure is well-defined without duplicates.
Current status
Currently, I am unable to determine whether this is a bug in SQL Server or a specific environmental issue. I am seeking guidance on how to gather more detailed diagnostic information, such as the exact error messages, the SQL Server version details, and the behaviors during index creation and conversion. Any suggestions on further troubleshooting steps or potential workarounds would be appreciated.
SQL Server Database Engine
  1. Deepesh Dhake 1,325 Reputation points
    2026-10-08T13:42:44.6766667+00:00
    That message is error 8601. Microsoft has fixed several 8601 bugs involving columnstore in past CUs (KB2981764, KB3172959).
    Converting a clustered columnstore index to a rowstore clustered index with DROP_EXISTING = ON is supported, so an internal QP error here is not expected behavior.
    Tests to narrow it down
    Retry the conversion with one change at a time:
    1. Remove SORT_IN_TEMPDB = ON
    2. Remove DATA_COMPRESSION = PAGE
    3. Add MAXDOP = 1
    4. First run ALTER INDEX [CCI] ON [dbo].[table] REORGANIZE WITH (COMPRESS_ALL_ROW_GROUPS = ON);, then retry
    The reason for test 4: with this few rows, the data is in an open delta rowgroup, not compressed segments. You can confirm that with sys.dm_db_column_store_row_group_physical_stats. Whether that matters for the bug is untested.
    To capture more detail
    Run an Extended Events session on error_reported, filtered to error_number = 8601, with the tsql_stack action. Also check the SQL Server LOG folder for any SQLDump* files from the time of the failure.
    Workaround to try
    Use DROP INDEX [CCI], then a separate CREATE CLUSTERED INDEX ... WITH (DATA_COMPRESSION = PAGE).
  2. Erland Sommarskog 138.7K Reputation points MVP Volunteer Moderator
    2026-10-08T15:06:12.8666667+00:00
    Thanks for the repro! I was able to reproduce the error on SQL 2022 CU27 and SQL 2025 CU9, that is, the latest public builds. So this has to be considered to be a bug in the product - or possibly a limitation. This was on my machines at home, not an SQL Server VM in Azure.
    It seems that the culprits are the nvarchar(4000) columns. When I remove these, I do not get the error. I was also able to run the script without error with only the column included_columns in the table.
    One workaround is to first drop the index and the run CREATE INDEX, but this means that SQL Server has to double the work. First convert the columnstore index to a heap and then to a B-tree.
    I tried the suggestions from Deepesh, and #1, #2 and #4 had no effect. However, MAXDOP = 1 seems to save the show. That is probably a better workaround than DROP + CREATE.
    As for how to get this bug addressed, there are two ways to go. One is to report it on https://feedback.azure.com/d365community/forum/04fe6ee0-3b25-ec11-b6e6-000d3a4f0da0 This is only to let Microsoft know and they will address it as they see fit. Be sure to include the repro. I've included a slightly clean-up version below, so that you easily can copy and paste.
    If this is an issue that is blocking you - that is, you cannot accept the workarounds - you will have to open a support case. Yes, I see that you have already opened a support case through the Azure portal. I'm uncertain how this works, but I suspect that the case you have opened is through a support plan you have with Azure, and this issue has nothing to do with Azure as such, but it is purely an SQL Server problem. So you may have to open a new case for SQL Server, all assuming that your organisation has support contract that permits this.
    drop table if exists [dbo].[table]
    CREATE TABLE [dbo].[table](
    [Id] [bigint] IDENTITY(1,1) NOT NULL,
    [server_name] [nvarchar](128) NOT NULL,
    [collected_date] [datetimeoffset](7) NOT NULL,
    [database_name] [nvarchar](128) NULL,
    [table_name] [nvarchar](128) NULL,
    [equality_columns] [nvarchar](4000) NULL,
    [inequality_columns] [nvarchar](4000) NULL,
    [included_columns] [nvarchar](4000) NULL,
    [impact] [bigint] NULL,
    [user_seeks] [bigint] NULL,
    [query_hash] [nvarchar](64) NULL,
    [query_plan_hash] [nvarchar](64) NULL,
    [first_seen_date] [datetimeoffset](7) NULL,
    [last_seen_date] [datetimeoffset](7) NULL,
    [appearance_count] [int] NULL
    ) ON [PRIMARY]
    GO
    CREATE CLUSTERED COLUMNSTORE INDEX [CCI] ON [dbo].[table]
       WITH (DROP_EXISTING = OFF, COMPRESSION_DELAY = 0, DATA_COMPRESSION = COLUMNSTORE) ON [PRIMARY]
    GO
    SET NOCOUNT ON
    DECLARE @NumRegistros INT = 1000; -- Cantidad de registros a insertar
    DECLARE @i INT = 0;
    WHILE @i < @NumRegistros
    BEGIN
       DECLARE @CollectedDate DATETIMEOFFSET(7) =
           DATEADD(DAY, -(ABS(CONVERT(BIGINT, CHECKSUM(NEWID()))) % 365), SYSDATETIMEOFFSET());
       DECLARE @FirstSeenDate DATETIMEOFFSET(7) =
           DATEADD(DAY, -(ABS(CONVERT(BIGINT, CHECKSUM(NEWID()))) % 90), @CollectedDate);
       DECLARE @LastSeenDate DATETIMEOFFSET(7) =
        DATEADD(DAY,
                 (DATEDIFF(DAY, @FirstSeenDate, @CollectedDate) + 1),
                  @FirstSeenDate);
    INSERT INTO [dbo].[table]
        [server_name],
        [collected_date],
        [database_name],
        [table_name],
        [equality_columns],
        [inequality_columns],
        [included_columns],
        [impact],
        [user_seeks],
        [query_hash],
        [query_plan_hash],
        [first_seen_date],
        [last_seen_date],
        [appearance_count]
    VALUES
        N'SQLSERVER-' + CAST(ABS(CHECKSUM(NEWID()) % 10) + 1 AS NVARCHAR(10)),
        @CollectedDate,
        N'Database_' + CAST(ABS(CHECKSUM(NEWID()) % 20) + 1 AS NVARCHAR(10)),
        N'Table_' + CAST(ABS(CHECKSUM(NEWID()) % 100) + 1 AS NVARCHAR(10)),
        -- Columnas de igualdad
        N'[Column_' + CAST(ABS(CHECKSUM(NEWID()) % 20) + 1 AS NVARCHAR(10)) + N']',
        -- Columnas de desigualdad
        -- Columnas incluidas
        N'], [Column_' + CAST(ABS(CHECKSUM(NEWID()) % 20) + 1 AS NVARCHAR(10)) + N']',
        -- Impacto entre 1 y 100
        ABS(CHECKSUM(NEWID()) % 100) + 1,
        -- User seeks entre 1 y 100000
        ABS(CHECKSUM(NEWID()) % 100000) + 1,
        -- Hash de consulta
        CONVERT(NVARCHAR(64), NEWID()),
        -- Hash del plan
        @FirstSeenDate,
        @LastSeenDate,
        -- Número de apariciones entre 1 y 500
        ABS(CHECKSUM(NEWID()) % 500) + 1
    SET @i += 1;
    END;
    PRINT CONCAT('Registros insertados: ', @NumRegistros);
    go
    go
    CREATE CLUSTERED INDEX [CCI]
    ON [dbo].[table] ([Id])
    WITH (DROP_EXISTING = ON, DATA_COMPRESSION = NONE, SORT_IN_TEMPDB = OFF)
    ON [PRIMARY];
