SOUND PROBLEMS WITH AN ACER DESKTOP
Peter Axon 0 Reputation points
2026-10-01T12:19:03.2433333+00:00
I currently have no sound on my Acer desktop. There is a white cross on my sound bar which says there is no sound device installed. However a check with Device Manager says Realtek is installed and working correctly. While i am about it my computer does have a microphone installed which has also fallen victim to the not working ethic. It hasn't been operational for over a year.
Any ideas?
Windows for home | Previous Windows versions | Devices and drivers
  1. Peter Axon 0 Reputation points
    2026-10-20T12:21:03.0533333+00:00
    Emma: Not sure if what I have is what you want. But I have followed your instructions, so here goes:
    I have a SNID number.
    I put it in to Drivers Section - Audio driver.
    Dowload option is Realtek 2024/03/18 6.0. 9601.1 Do I download?
    I may be wrong but can't help but believe that a stupid error on my part is responsible for this. My computer is in good shape and is not used for endless downloads - or any in fact. I suspect that somehow I have disabled the sound and microphone and that there is a simple fix for this.
    Regards
    Peter
  2. Emma1-N 14,925 Reputation points Microsoft External Staff Moderator
    2026-10-02T00:17:56.5066667+00:00
    Welcome Peter Axon,
    Thank you for posting to the Microsoft Q&A forum.
    To help narrow this down, could you tell us:
    • Which version of Windows are you using (Windows 10 or Windows 11)?
    • Did the audio stop working recently, or has it been missing for a long time?
    • Does your Acer model use the built-in speakers, or are external speakers connected?
    In the meantime, please try these quick checks:
    • Press Windows + R, type services.msc, and press Enter.
    • Find Windows Audio and Windows Audio Endpoint Builder"
    • Ensure both services show Running and Automatic. If not, right-click each service and select Start
    Then check whether an audio device now appears.
    Also, please open Settings > System > Sound and let me know whether any device is listed under Output or if the list is completely empty.
    I look forward to your reply.
