A Microsoft open-source framework for building native device applications spanning mobile, tablet, and desktop.
Yes, and you're closer than you think. What you want exists as an official template called the .NET MAUI Blazor Hybrid and Web App solution template. It sets up a solution targeting Android, iOS, Mac, Windows and Web, with a Blazor Web App, a MAUI Blazor Hybrid app, and a shared Razor class library (RCL) holding all the UI components.
So to answer your exact question: it's not literally one project, it's one solution with three projects, but you write your pages once in the shared library and both the mobile app and the website render the same UI. That's the maximum reuse .NET offers today, and it's the officially recommended pattern. For the bits that must differ per platform (file access, camera, etc.), the template includes sample code showing how to use dependency injection to swap implementations between the Hybrid and Web apps.
To try it: install the MAUI workload and run dotnet new maui-blazor-web, or pick the template in Visual Studio.
Your background fits this well. Blazor uses Razor and C#, so coming from MVC it'll feel familiar fast. One architecture tip: keep EF Core and SQL Server behind an ASP.NET Core Web API. The web app and the mobile app both call that API, since a mobile app should never talk to SQL Server directly.
References: https://learn.microsoft.com/en-us/aspnet/core/blazor/hybrid/tutorials/maui-blazor-web-app https://learn.microsoft.com/en-us/aspnet/core/blazor/hybrid/class-libraries-best-practices
