will not load sites on edge
Derek Loveday 0 Reputation points
2026-09-06T10:22:43.7633333+00:00
certain sites wont load like nation lottery & amazon es only loads script
Microsoft Edge | Website issues | Windows 11
  1. GsN5034 - IA 76,465 Reputation points Independent Advisor
    2026-09-06T11:04:28.9433333+00:00
    Try turning off your Wi-Fi router and turn it ON again.
    Then connect your device to your Wi-Fi network and check whether the webpages load properly.
    If you're still having issues, try another web browser or clear the browsing history, cache, and cookies to see if it works.
    • Paste this link on the edge address bar - edge://settings/clearBrowserData
    • Then, select time range to All time.
    • Make sure you select browsing history, cookies and other site data and cached images.
    • Click 'Clear now'.
    • Restart your web browser and PC.
    Then, see if you can access those sites normally.
