How to fix issue with "Device health attestation isn't supported on this device."
Connor McGuire 0 Reputation points
2026-09-02T13:46:06.66+00:00
I have tpm 2.0 enabled in bios but when i go to my security processor troubleshooting it says "Device health attestation isn't supported on this device. Clearing your TPM might help enable it." Unfortunately clearing my TPM has not done anything to fix the issue nor can I locate any resources to assist me in understanding the issue or fixing it.
Microsoft Security | Microsoft Defender | Other
    2026-09-02T13:46:24.3566667+00:00
    Device health attestation isn't supported on this device means Windows does not receive enough information from the device to determine why TPM may not be working properly. Clearing the TPM does not fix this specific condition in all cases.
    Use this troubleshooting path:
    1. Verify the TPM is present and the version is correct.
      • Open Windows Security > Device security.
      • Confirm the Security processor section is present.
      • Select Security processor details and check Specification version.
      • For Windows 11, TPM 2.0 is required.
    2. Check whether the device meets health attestation hardware requirements.
      • Press Win + R, run tpm.msc, and confirm the Specification Version.
      • Open an elevated Command Prompt and run msinfo32.
      • In System Summary, verify:
        • BIOS Mode = UEFI
        • PCR7 Configuration = Bound
      • Open an elevated PowerShell window and run:
             Confirm-SecureBootUEFI
        Confirm it returns True.
      • Run:
             manage-bde -protectors -get $env:systemdrive
        Verify the drive is protected by PCR 7.
    3. If TPM-related errors also appear in Security processor troubleshooting, follow the message-specific action.
      • If Windows says a firmware update is needed, install the TPM or motherboard firmware update from the device manufacturer.
      • If TPM is disabled, enable it in BIOS/UEFI.
      • If Windows reports general TPM problems, restart the device and recheck.
    4. If the message remains after the checks above, contact the device manufacturer.
      • Microsoft’s guidance for this exact message is that the device does not provide enough information to determine the cause.
      • If problems continue after addressing the visible TPM error messages, manufacturer support is the next step.
    Important: clearing the TPM can cause data loss because TPM-protected keys and data can be removed. Use Windows tools such as Windows Security or tpm.msc for TPM operations, not direct UEFI clearing.
