Search Engine
John -PC 120 Reputation points
2026-08-28T11:12:31.59+00:00
I have set the default search engine to "Google" in Edge > settings, but it still does Bing searches - WHY?
Microsoft Edge | Tabs, address bar, and search | Windows 10
AI answer
2026-08-28T11:12:51.26+00:00
Most commonly, Edge is still using Bing because the search is happening from a place that is not using the address bar setting, or because an extension changed search behavior.
Check these items:
  1. Confirm the address bar search engine setting In Edge, go to: Settings and more > Settings > Privacy, search, and services > Search and connected services > Address bar and search Then verify Search engine used in the address bar is set to Google.
  2. Make sure the search is being done from the address bar If the search is started from a different search box, it may not follow the same behavior. A Microsoft Q&A answer specifically notes that setting Search on new tabs uses search box or address bar to Address bar makes new tab searches use Google.
  3. Visit Google once if Google is missing or not fully applied Edge adds search engines after a search is performed with that engine in the address bar. Search once using Google in the address bar, then return to Address bar and search and select it.
  4. Check extensions Some extensions can change important browser settings such as the default search engine. Edge may disable extensions that try to modify default settings without permission, but installed extensions can still affect search behavior.
    • Go to Settings and more > Extensions > Manage extension
    • Turn off suspicious or unnecessary extensions
    • Then test search again
  5. If the device is in Windows S mode In Windows 10/11 in S mode, Bing is the default search engine in Microsoft Edge.
So the likely reasons are:
  • the search is being done from a new tab search box instead of the address bar,
  • an extension is interfering,
  • Google was not properly added as a search provider,
  • or the PC is running in S mode.
2 additional answers
  1. Rodrigo Queiroz 78,755 Reputation points Independent Advisor
    2026-08-28T12:10:08.5866667+00:00
    Hi, I'm Rodrigo and I will help you.
    Make sure you are using the address bar to make searches. If you use the search bar on the new tab page, the searches will be done on Bing regardless of your default search engine setting.
  2. Deleted
