A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
1
Are all the other Office apps like Word and Excel working correctly?
2
In PowerPoint, is this problem only affecting one PowerPoint presentation file or will the PowerPoint app just not open, and if so, what error is indicated when you try to open PowerPoint.
If the error you see is a popup dialog with a 'Repair Now' button and that option is not resolving the problem, then the best option is to perform an online repair of the Office apps.
Before performing this process, please log into your Microsoft account on this link (https://account.microsoft.com/services/) and check to ensure your Office licence or Microsoft 365 subscription is listed correctly on your account.
Open the Settings App (gear icon on your Start Menu)
Go to Apps, then scroll down to find Microsoft Office
Select that and choose Modify - Online Repair
That should fix any issues with your Office Installation.
