Using Outlook for iOS in business environments for email and scheduling
Try these checks in order:
- Check whether Outlook.com is having a service interruption. If the service status is not green, wait and try again.
- Check mailbox and cloud storage capacity. If Microsoft cloud storage or the mailbox is full, email cannot be sent or received. Messages sent to the account while storage was full are bounced back to the sender and are unrecoverable.
- Check the account state. If the password was changed recently, update it on the phone. The account can also be temporarily blocked because of unusual sign-in activity.
- If the problem is only on the phone, remove the mobile device partnership and sync again:
- In Outlook.com, go to Settings > General > Mobile devices.
- Select the phone in the list and delete the device partnership.
- Select Save.
- Power off the phone completely.
- Turn it back on after a few seconds and sync the mailbox again.
- If using Outlook Lite, also check these common causes:
- The app may have been closed before sending completed, and the message may now be in Drafts.
- The daily message sending limit may have been exceeded.
- For mobile-device send/receive troubleshooting, the Microsoft Support and Recovery Assistant can be used for automatic checks.
