need help finding memory setup guide for 50 VMs
Horak David 0 Reputation points
2026-08-14T12:33:08.0366667+00:00
Hello Support team,
I bought 50 VM packages thru our reseller however I was told to get the memory allocation guide from your support portal. I loged in the support portal but I dont see the memory allocation guide there. Can you please walk me through this?
Thanks
Windows for business | Windows 365 Enterprise
  1. Allan Solomon Mejia 3,840 Reputation points
    2026-08-14T19:25:41.8933333+00:00
    Hello @Horak David
    There isn't a Microsoft memory-allocation guide based simply on purchasing a specific number of VMs. Memory sizing is determined by the workloads running inside those VMs, not by the VM count or licensing/package quantity.
    For example, if these are Hyper-V VMs, you should consider:
    • Guest OS and application memory requirements
    • Number of VMs expected to run concurrently
    • Memory required by the Hyper-V host
    • Whether you're using static or Dynamic Memory
    • Startup, minimum, and maximum RAM settings
    • Expected workload peaks and available physical RAM
    Microsoft recommends providing enough physical memory for the expected guest VM requirements plus sufficient memory for the host operating system. Hyper-V Dynamic Memory can also adjust VM memory according to workload demand.
    So, for example, 50 VMs configured with 8 GB each would represent 400 GB of configured guest memory, before considering host requirements and your Dynamic Memory/overcommit strategy. That doesn't automatically mean the host needs exactly 400 GB, the actual design depends heavily on workload behavior.
    Could you clarify what you mean by the "50 VM package" and which Microsoft product or reseller offering you purchased? Also provide the host specifications and what workloads/OS will run in the VMs. That will make it possible to point you to the correct sizing guidance.
    Please "Accept the Answer" if this information helped you.
