how to enable print option in vertical scrolling content in the power apps?
Vishal Praveen 0 Reputation points
2026-08-07T10:29:09.19+00:00
here i had problem from the print option from power apps. I want to print the whole vertical scrolling content but when i touch print button it only print what present in the screen at the time. only viewed content only had printed. but i want to print whole scrollable content User's image
Microsoft 365 and Office | Development | Microsoft 365 App Publishing
  1. Vishal Praveen 0 Reputation points
    2026-08-07T10:31:24.83+00:00
    but i had more content in the vertical scrollable content, when i create new screen means it is does not match in the single.. at the time what i do
  2. Hin Vo 445 Reputation points Independent Advisor
    2026-08-07T11:06:17.53+00:00
    Please note that this is a public forum. When posting error messages or other technical details in the future, please make sure to remove or mask any personal or organizational information to help protect sensitive data and privacy.
    Hi @Vishal Praveen
    Based on my research, looks like the Print function is designed to print the current screen. From my understanding, when content is placed inside a scrollable container, Power Apps only prints the content that is currently rendered and visible within the screen viewport. Content located outside the visible scroll area is not automatically expanded or included in the print output.
    User's image Reference: Print function - Power Platform | Microsoft Learn
    Therefore, the behavior you are experiencing appears to be expected and is currently by design. I also found an external document that discusses a similar behavior and may provide additional context for your concern.
    User's image You can refer via: https://devoworx.net/powerapps-print-function/
    Please note that this link is shared by community members for your convenience. It points to a third-party site that is not managed or verified by Microsoft. I can’t guarantee the quality, safety, or suitability of any content or software found there. Please review carefully and make sure you understand any potential risks before using it.
    I hope this helps.
    Please feel free to correct me if I misunderstood your request. If you have any additional concerns, feel free to comment below. I would be more than happy to assist.
