keyboard problem
Valt Renel Consad 0 Reputation points
2026-08-04T07:36:31.9866667+00:00
my keyboard is not working I think I accidental press something but the function keys is working
Windows for home | Windows 10 | Accessibility
  1. DaveM121 947.9K Reputation points Independent Advisor
    2026-08-04T08:09:13.51+00:00
    1
    Try pressing Fn + Esc to test if that gets the keyboard working.
    2
    If not, open Command Prompt, then paste in this command and press Enter:
    msdt.exe -id KeyboardDiagnostic
    Run that Keyboard Troubleshooter to see if that can solve the problem.
    3
    If that does not resolve this for you
    Open Device Manager
    Expand the Keyboards section
    Right click your keyboard and choose 'Uninstall'
    Then restart your PC
