What's the best way to evaluate prompt quality in Azure AI Foundry?
jamess jamess 85 Reputation points
2026-07-31T09:49:35.4766667+00:00
I'm currently learning Azure AI Foundry and experimenting with prompt-based applications.
One area I'm trying to understand better is prompt evaluation. Beyond manually reviewing outputs, what methods or tools do you use to measure whether prompts are performing well?
For example:
  • Do you use built-in evaluation features in Azure AI Foundry?
  • How do you measure consistency and response quality?
  • What metrics are most useful for production applications?
  • Are there any Microsoft best practices for testing prompts before deployment?
I'd appreciate hearing how others approach prompt evaluation in real-world Azure AI projects.
Thanks!
Foundry Tools
Foundry Tools
Formerly known as Azure AI Services or Azure Cognitive Services is a unified collection of prebuilt AI capabilities within the Microsoft Foundry platform
Anshika Varshney 15,625 Reputation points Microsoft External Staff Moderator
2026-08-04T15:30:35.3533333+00:00
Hi @jamess jamess ,
In Azure AI Foundry, prompt evaluation is most effective when you combine automated evaluations with human review. Here are some practical troubleshooting and validation steps you can follow:
  1. Create a representative evaluation dataset
    • Prepare a JSONL dataset containing real-world inputs and expected outputs.
    • Include edge cases, ambiguous queries, and common user scenarios.
  2. Use Azure AI Foundry Evaluation
    • Run evaluation jobs using the same prompt, model, temperature, and parameters that you plan to use in production.
    • Compare multiple prompt versions under identical conditions.
  3. Review key evaluation metrics
    • Accuracy/Correctness: Does the response answer the question correctly?
    • Relevance: Is the response aligned with the user's intent?
    • Groundedness (for RAG scenarios): Is the answer based on the provided context?
    • Completeness: Are all parts of the question addressed?
    • Fluency: Is the response clear and natural?
  4. Perform A/B testing
    • Modify only one prompt component at a time (instructions, examples, format, etc.).
    • Compare evaluation results to identify which changes improve quality.
  5. Validate consistency
    • Run the same test dataset multiple times.
    • Review responses for variability, especially when using higher temperature settings.
  6. Monitor after deployment
    • Review user feedback and production telemetry regularly.
    • Re-evaluate prompts whenever the model, data source, or business requirements change.
Microsoft documentation related to prompt evaluation and comparison can be helpful:
  • Azure AI Foundry Evaluation
  • Evaluate and compare prompt versions
  • RAG evaluation and groundedness metrics
These practices help establish a repeatable process for measuring prompt quality and detecting regressions before deployment.
Thankyou!
kagiyama yutaka 5,330 Reputation points
2026-07-31T10:36:10.2766667+00:00
I think prompt quality in Azure AI Foundry is checked by running the same prompt on a small JSONL or table dataset in an Evaluation run and reading the built‑in metrics under the same settings, and Prompt Flow gives its own tests and regression checks.
AI answer
2026-07-31T09:49:59.2233333+00:00
A strong approach in Azure AI Foundry is to combine structured offline evaluation with ongoing production monitoring.
A practical evaluation workflow is:
  1. Create a ground-truth test set Build a labeled dataset that represents the expected behavior for the prompt. Keep it relevant, diverse, and balanced for the intended task and domain. For Azure OpenAI evaluation, the quality of this ground-truth data is critical because inaccurate labels produce misleading evaluation results. The dataset format for evaluation is JSONL.
  2. Use the Evaluation API or Foundry evaluation features Azure OpenAI Evaluation lets model outputs be tested directly through API calls and assessed programmatically. This is the main built-in path for repeatable prompt evaluation instead of manual spot-checking.
  3. Match evaluation prompts to production prompts The prompt used during evaluation should match the prompt planned for production. If few-shot examples will be used in production, include them in evaluation too. This makes the results meaningful.
  4. Measure with multiple metrics, not one Microsoft guidance recommends using a combination of metrics to capture different aspects of performance, such as:
    • Accuracy
    • Fluency
    • Relevance
    For RAG-style prompt evaluation, useful metrics include:
    • Groundedness: whether the prompt strongly instructs the model to use only provided context
    • Completeness: whether all parts of the question are addressed
    • Utilization: whether relevant context chunks are actually used
    • Relevance: whether the answer stays on the question
    • Correctness: whether the prompt handles ambiguity or conflicting information well
  5. Run controlled A/B prompt experiments Test prompt variants systematically and change one variable at a time, such as:
    • grounding instruction wording
    • context ordering
    • number of few-shot examples
    Then compare evaluation metrics across versions. This is one of the clearest ways to measure consistency and quality improvements.
  6. Track prompt versions with evaluation results Document each prompt version together with:
    • the prompt text
    • hyperparameters such as temperature, top-p, and max tokens
    • evaluation metric results across the test set
    • what changed from the previous version and why
  7. Include human review for subjective quality Automated scoring is useful, but Microsoft also recommends human-in-the-loop evaluation so subjective qualities are captured accurately.
  8. Continue evaluation after deployment Prompt engineering is iterative. Continue testing to detect regressions and negative user experience over time rather than treating evaluation as a one-time predeployment step.
For consistency and response quality, the most useful pattern is:
  • fixed JSONL evaluation dataset
  • same production-like prompt
  • repeated evaluation runs across prompt versions
  • comparison of metric changes over time
  • human review on edge cases
For production applications, the most useful metrics depend on the app type, but the context specifically highlights:
  • accuracy
  • fluency
  • relevance
  • groundedness
  • completeness
  • utilization
  • correctness
If custom scoring is needed, prompt evaluation can also include custom evaluators or prompt-based judges. In the Databricks-based example, a custom judge is created with make_judge to score whether a summary follows a two-sentence requirement. That pattern is useful when built-in metrics do not fully capture business-specific quality requirements.
A solid best-practice baseline before deployment is:
  • curate a high-quality ground-truth dataset
  • use JSONL evaluation data
  • evaluate with the same prompt intended for production
  • use multiple metrics
  • run A/B tests with one prompt change at a time
  • document versions and results
  • include human review
  • keep evaluating after release
1 additional answer
  1. jamess jamess 85 Reputation points
    2026-08-01T08:18:25.5466667+00:00
    Thank you for the detailed explanation. The workflow of using a ground-truth JSONL dataset, multiple evaluation metrics, and A/B testing prompt variations makes a lot of sense. I'll review the Azure AI Foundry evaluation features and apply these practices while refining my prompts. This was very helpful!
