Using Publisher after October 1 2026
Maria Murace 30 Reputation points
2026-07-29T04:18:06.2866667+00:00
Ho do i continue to use Publisher in my Microsoft subscription 365 after October as I would like to continue using this software
Microsoft 365 and Office | Publisher | For home
  1. Kai-H 26,385 Reputation points Microsoft External Staff Moderator
    2026-07-29T09:01:38.7833333+00:00
    Hi, Maria Murace
    Unfortunately, you will not be able to continue using Publisher through a Microsoft 365 subscription after October 1, 2026. Publisher will be removed from Microsoft 365, and subscribers will no longer be able to open or edit .pub files in the Publisher app. There is no subscription setting or supported workaround that will keep it active.
    Before that date, it is recommended that you convert important Publisher files. Open each file, select File > Save As, and save a PDF copy for viewing or printing. If you need to edit the content later, Word can open the PDF and convert it into an editable document, although complex layouts may change. A PowerShell conversion script is also available for people with many .pub files.
    A perpetual, one-time-purchase version of Publisher can still be installed and used after October 1, but it will be unsupported and will not receive updates. It is not included with your Microsoft 365 subscription. For future projects, Word or PowerPoint are the recommended alternatives. See Publisher retirement guidance.
    Thank you for your patience in reading, I hope this information has been helpful to you.
    If the answer is helpful, please click "Yes" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
  2. Maria Murace 30 Reputation points
    2026-08-02T01:57:52.39+00:00
    Where can i purchase a Perpetual one time version of publisher and can i install it now
  3. Luanne Newman 0 Reputation points
    2026-09-10T23:02:01.62+00:00
    How do I download the Perpetual User version of Publisher?
