e.g., I'm using touchpad and I have to double click (ONLY on Roblox everything else doesn't require two fingers)
greyson 0 Reputation points
2026-07-17T04:54:16.1+00:00
I am trying to click on games/friends and it wont let me only until i use two fingers to click on it, can you please help me fix this?
Windows for home | Other | Search, touch, and mouse
  1. Someone 0 Reputation points
    2026-08-06T17:26:10.2266667+00:00
    I don't know because someone said on the settins get help said this - e.g., I'm using touchpad and I have to double click (ONLY on Roblox ...
    And i froze and thought since I can't click anything that means I can use 2 fingers i tried it and boom it worked but I want to know how to help me fiz it
  2. Carl-L 21,320 Reputation points Microsoft External Staff Moderator
    2026-07-18T13:35:34.87+00:00
    Hello greyson,
    Thanks for replying.
    That is weird since the default behavior of tapping 2 fingers is for the right click. In this case, can you please try this quick fix first?
    • Go to Settings > Apps > Installed apps.
    • Select the ellipsis next to the game > Advanced Settings.
    • Select "repair"
    • If that doesn't work, select "reset".
  3. Carl-L 21,320 Reputation points Microsoft External Staff Moderator
    2026-07-17T09:28:47.9766667+00:00
    Hello greyson,
    Putting 2 fingers on the touchpad is the gesture of scrolling the mouse wheel and tapping it with 2 fingers means that you're using the right click. Before we proceed further, may I know if you have to choose anything else inside Roblox using 2 fingers or only on games/friends? (The option for example).
    Additionally, if you have a physical mouse, can you please check if the right click function the same way?
    I'm waiting for your reply.
