Using a lower‑wattage genuine Surface power supply will not damage a Surface Laptop 4, but it may charge slowly or not at all.
From the charging requirements:
- Surface Laptop 4 is listed under “Devices that charge using USB-C or Surface Connect” with:
- Minimum wattage: 60W
- Recommended wattage for Fast charging: 60W
- Microsoft power supply: Model 1706, 60W (15V @ 4A).
What this means in practice:
- A lower‑wattage charger (for example, 31W or 39W) generally will not harm the device if it is a genuine Microsoft or Microsoft‑licensed Surface charger.
- However, because it does not meet the 60W minimum, the laptop may:
- Charge very slowly, or
- Not charge at all while in use (battery may still drain if workload is high), and
- Not support Fast Charging.
Microsoft also notes for USB‑C PD charging that if a lower‑wattage charger is used, the device “may charge slowly or not at all” and won’t use Fast Charging, and recommends using a charger that provides the recommended wattage.
So:
- Using the 65W Surface charger is fully appropriate and meets/ exceeds the 60W requirement.
- Using 31W or other sub‑60W Surface chargers is not recommended for regular use because they do not meet the minimum power requirement, but they are not expected to damage the device; they may simply be ineffective or very slow.
For best performance and to ensure reliable charging, use a genuine Surface power supply that meets the 60W requirement (such as the 60W Model 1706) or a USB‑C PD charger that provides at least 60W.
