A set of .NET Framework managed libraries for developing graphical user interfaces.
The error indicates that Visual Studio can’t load the base class for the form at design time, so the Windows Forms Designer fails to open.
For Windows Forms, this typically happens when the designer cannot load the assembly that contains the base form type. One documented cause is when the project (or an assembly containing the base form) is built targeting x64 or Itanium, while Visual Studio itself runs as a 32-bit process.
When copying a project to another directory and reopening it, ensure:
- The project builds successfully in the new location.
- The Windows Forms project (and any assemblies that contain base form classes) are not compiled as x64/Itanium.
To fix it:
- Open the copied project in Visual Studio.
- Open the project properties:
- For Visual C#: go to Project → Properties → Build and set Platform target to
Any CPU. - For Visual Basic: go to Project → Properties → Compile → Advanced Compile Options and set Target CPU to
AnyCPU.
- Rebuild the solution.
- Reopen the form in the designer.
Using AnyCPU ensures the form classes can be loaded both in Visual Studio (32-bit process) and at runtime, and prevents the “base class could not be loaded” designer error after copying the project.
