I am not able to configure auto-scaling for my existing VMSS node pools for my AKS cluster
cargobuddy 30 Reputation points
2026-06-20T17:00:49.8933333+00:00
I have a private AKS cluster, with two VMSS node pools, one for system and one for user. The node pool, when created, is preconfigured with manual scaling. However, I want to leverage the auto-scaling feature. For that I applied the below command, where I got the error as shown:
Command:
az aks nodepool update --resource-group <<rg>> --cluster-name <<cluster-name>>--name <<pool-name>> --enable-cluster-autoscaler --min-count 2 --max-count 2
Error:
(OperationNotAllowed) .properties.nodeProvisioningProfile.mode cannot be Auto unless all AgentPools have property .properties.enableAutoScaling set to one of [false].
Code: OperationNotAllowed
Message: .properties.nodeProvisioningProfile.mode cannot be Auto unless all AgentPools have property .properties.enableAutoScaling set to one of [false].
Azure Virtual Machine Scale Sets
Azure compute resources that are used to create and manage groups of heterogeneous load-balanced virtual machines.
  1. Alex Burlachenko 25,290 Reputation points MVP Volunteer Moderator
    2026-06-22T10:50:38.2433333+00:00
    hi cargobuddy, thx for sharing urs issue here at Q&A portal,
    check whether the AKS cluster is using Node Auto-Provisioning/Auto mode. If yes, don’t enable the classic autoscaler on existing node pools. Pick one model NAP/Karpenter-style provisioning, or classic node pool autoscaler. Mixing both is what’s causing the OperationNotAllowed error, this error doesn’t look like a VMSS problem directly. It looks like ur AKS cluster has Node Auto-Provisioning / Auto mode enabled, and that conflicts with enabling the classic cluster autoscaler on existing agent pools.
    Microsoft describes Node Auto-Provisioning as a newer AKS feature that automatically provisions and manages nodes based on pending pod needs, using Karpenter under the hood. That’s different from the classic AKS cluster autoscaler, which scales existing node pools. The key part of the error is this
    nodeProvisioningProfile.mode cannot be Auto unless all AgentPools have enableAutoScaling set to false
    AKS is saying, “u can’t use this Auto node provisioning mode while any normal node pool autoscaler is enabled.” Yeah, very Azure-ish wording technically correct, emotionally hostile.
    I’d verify the cluster-level node provisioning mode
    az aks show \
    --resource-group <rg> \
    --name <cluster-name> \
    --query "nodeProvisioningProfile"
    check the node pools
    az aks nodepool list \
    --cluster-name <cluster-name> \
    --query "[].{name:name, enableAutoScaling:enableAutoScaling, count:count, min:minCount, max:maxCount, mode:mode}"
    If nodeProvisioningProfile.mode is Auto, then the fix is not to enable autoscaler on the existing VMSS node pools. U either keep Node Auto-Provisioning and leave enableAutoScaling false on all agent pools, or u disable Node Auto-Provisioning and then use the classic cluster autoscaler on the node pools.
    One more thing this command doesn’t really make sense for autoscaling
    That means the autoscaler has nowhere to scale. Min and max are both 2, so it’s basically manual scaling wearing a fake mustache. Use something like --min-count 2 --max-count 5 if u actually want scaling.
    https://learn.microsoft.com/en-us/azure/aks/cluster-autoscaler
    rgds,
    Alex
    If my answer was helpful pls mark it and additional thx if u follow me at Q&A portal
