Silent BitLocker Deployment via Intune for Remote Laptops
Micheal Brown 45 Reputation points
2026-06-19T15:37:33.0333333+00:00
Our sales reps frequently travel with company laptops containing confidential client contracts. To mitigate data breach risks if a device is stolen, we want to enforce BitLocker encryption.
Can Microsoft Intune be configured to silently enable BitLocker on all remote endpoints without prompting the user?
How do we ensure that recovery keys are automatically backed up to the cloud so users don't lose them?
Windows for business | Windows 365 Business
    2026-06-19T15:38:09.6533333+00:00
    Yes. Microsoft Intune can silently enable BitLocker on remote Windows devices and automatically escrow recovery keys to the cloud, provided devices and policies meet specific requirements.
    1. Silent BitLocker prerequisites
    For silent BitLocker enablement, devices must meet these conditions:
    • OS:
      • Admin users: Windows 10 version 1803 or later, or Windows 11
      • Standard users: Windows 10 version 1809 or later, or Windows 11
    • Device configuration:
      • Microsoft Entra joined or Microsoft Entra hybrid joined
      • TPM 1.2 or later
      • Native UEFI BIOS mode
      • Secure Boot enabled
      • Windows Recovery Environment (WinRE) configured and available
    Silent enablement automatically chooses the encryption type:
    • Full disk encryption on non‑modern standby devices
    • Used space only encryption on modern standby devices
    This behavior can’t be customized for silent encryption scenarios.
    Use an Endpoint security > Disk encryption policy in Intune:
    1. Create a BitLocker profile under Endpoint security.
    2. In the BitLocker profile, configure:
      • Require Device Encryption = Enabled
      • Allow Warning For Other Disk Encryption = Disabled
      • After disabling warnings, set Allow Standard User Encryption = Enabled if devices are used by standard (non‑admin) users.
    This combination enables BitLocker silently without user interaction.
    Important: Disabling “Allow Warning For Other Disk Encryption” means BitLocker will proceed even if third‑party disk encryption is present. This can cause data loss, system instability, or complex recovery scenarios. Use device inventory to ensure no third‑party disk encryption is installed before deploying.
    3. TPM startup settings for silent encryption
    Silent BitLocker requires no user interaction at startup, so TPM PINs/keys must not be required.
    In the same BitLocker profile under Operating System Drives:
    1. Set Require additional authentication at startup = Enabled.
    2. Then configure:
      • Configure TPM startup PIN = Do not allow startup PIN with TPM
      • Configure TPM startup key = Do not allow startup key with TPM
      • Configure TPM startup key and PIN = Do not allow startup key and PIN with TPM
      • Configure TPM startup = Allow TPM or Require TPM
    Also review any security baselines (for example, Microsoft Defender baseline) to ensure they do not enable TPM startup PIN or key, as that would block silent enablement.
    4. Alternative: Device configuration policy for silent BitLocker
    If using a Device configuration > Endpoint protection policy instead of Endpoint security:
    Under the Endpoint protection template (Windows Encryption):
    1. Warning for other disk encryption = Block
    2. Allow standard users to enable encryption during Microsoft Entra join = Allow
    3. User creation of recovery key = Allow or Do not allow 256‑bit recovery key
    4. User creation of recovery password = Allow or Require 48‑digit recovery password
    And configure TPM startup options:
    1. Compatible TPM startup = Allow TPM or Require TPM
    2. Compatible TPM startup PIN = Do not allow startup PIN with TPM
    3. Compatible TPM startup key = Do not allow startup key with TPM
    4. Compatible TPM startup key and PIN = Do not allow startup key and PIN with TPM
    5. Automatic backup of recovery keys to the cloud
    Intune integrates with BitLocker so that recovery keys are automatically backed up and centrally visible:
    • After Intune encrypts a Windows device with BitLocker, recovery keys can be viewed and managed via the Intune encryption report.
    • This ensures keys are stored in the cloud and available to admins if users lose them.
    • For additional security, configure Configure Recovery Password Rotation (via the BitLocker CSP) to automatically rotate recovery passwords after use.
    6. Monitoring and rollout best practices
    To safely roll out silent BitLocker for remote laptops:
    1. Assess environment:
      • Identify existing disk encryption software using device inventory.
      • Plan to remove third‑party encryption before BitLocker deployment.
    2. Pilot deployment:
      • Test silent BitLocker on a small, representative group of remote laptops.
    3. Monitor encryption status:
      • Use the Intune encryption report to track which devices are encrypted and confirm recovery keys are present.
    4. Prepare rollback/recovery procedures:
      • Ensure support processes exist for handling devices that encounter encryption conflicts or boot issues.
    With these prerequisites and policies in place, Intune can silently enforce BitLocker on remote endpoints and automatically escrow recovery keys to the cloud, minimizing user involvement while protecting confidential data.
  2. Tracy Le 11,535 Reputation points Independent Advisor
    2026-06-19T16:19:10.5233333+00:00
    Hi Micheal Brown,
    Microsoft Intune can absolutely be configured to silently enforce BitLocker encryption on your sales team's remote laptops without requiring any user interaction or administrative prompts. To achieve a completely transparent background deployment, you need to navigate to the Microsoft Intune admin center and create an Endpoint Security profile under the Disk Encryption template. Within the configuration settings, you must set Hide recovery options during BitLocker setup to Yes and enforce Allow standard users to enable encryption during Azure AD Join to Allow. This structural adjustment forces the Windows BitLocker CSP engine to initiate drive encryption instantly in the background, provided the laptops are equipped with a compatible Trusted Platform Module (TPM) 2.0 chip and the users are logged in with their corporate cloud identities.
    To guarantee that recovery keys are automatically backed up to the cloud so your users never lose access, you must configure the escrow dependencies within the same Intune policy before encryption begins. In the configuration settings, you need to set BitLocker backup to Microsoft Entra ID to Enabled, select the option to backup both recovery passwords and key packages, and strictly enforce the setting Require device to back up recovery information to Microsoft Entra ID before encryption is allowed. This parameter acts as a critical safeguard, ensuring that the local Windows client will block the encryption process entirely until it receives a successful HTTP status code verifying that the 48-digit recovery key has been securely escrowed into the device's cloud object profile in Microsoft Entra ID. Once deployed, you can verify compliance and retrieve these backup keys directly from the Devices blade or the Entra ID portal.
    Tracy Le.
