Downloads to WSUS not working in my MECM system with Software Update Point
Keith Craig 0 Reputation points
2026-06-19T14:16:05.47+00:00
I'm having a problem with a SUP in MECM. I have installed a brand new instance on a standalone primary server. All the diagnostics suggest that WSUS is communicating with Microsoft and with the SUP. However when I try to synchronise using SUP the softwaredistribution log is simply full of the following type of error. 2026-06-19 13:56:56.370 UTC Warning WsusService.15 DBConnection.ExecuteCommandNoResult SqlException occurred. Number 50000 and message invalid update identity (AtLeastOne Prerequisite) in XML for update 4F33682F-6D6E-47DC-90EE-07BA8F0E2E60\100
As I understand it this is a corrupted download, but it appears every download falls into that category. I have limited the initial sync to only critical and security updates for Windows 11 so it isn't overwhelmed. I have also wiped the system and rebuilt it to make sure the SUSDB SQL DB is clean, and there is not cached WSUS data I am aware of. I running Endpoint MECM 2603 on a Windows 2022 server. The other component of MECM seem to be working without issue. Does anyone have any ideas as to why these download don't work. Thanks
Microsoft System Center | Other
    2026-06-19T14:16:45.6433333+00:00
    The error in SoftwareDistribution.log indicates WSUS is rejecting update metadata during synchronization, so focus on WSUS health, connectivity to Microsoft Update, and EULA/content download rather than MECM itself.
    Use these checks and remediations on the WSUS/SUP server:
    1. Verify WSUS health
      • On the WSUS server, run:
             %ProgramFiles%\Update Services\Tools\wsusutil.exe checkhealth
      • Check the Application log in Event Viewer for WSUS-related errors. If WSUS components are unhealthy, Configuration Manager can’t synchronize updates.
    2. Confirm WSUS can connect to Microsoft Update
      • Synchronization and EULA/content download failures often cause metadata import errors.
      • From the WSUS server:
        • Ensure the WSUS server has Internet access.
        • Verify the firewall allows communication to Microsoft Update as described in Connection from the WSUS server to the Internet.
        • If a proxy is used, verify the proxy settings for the Software Update Point are correct.
    3. Check for EULA/content download issues
      • In %ProgramFiles%\Update Services\LogFiles\SoftwareDistribution.log, search for .txt and other EULA-related entries to see if EULAs or other content are failing to download.
      • If EULAs or other content are missing or corrupted, run:
             %ProgramFiles%\Update Services\Tools\wsusutil.exe reset
        This forces WSUS to re-download missing content, including EULAs.
    4. Validate WSUS–MECM connectivity
      • If the SUP is remote from the site server, install the WSUS Administration console on the site server and test connectivity:
        1. Start the WSUS Administration console on the site server.
        2. Right-click Update ServicesConnect to Server.
        3. Enter the WSUS server FQDN and correct port, then connect.
      • If the console cannot connect, resolve that connectivity issue first; otherwise WCM/WSyncMgr will fail even if WSUS itself is healthy.
    5. Check WSUS synchronization endpoint and TLS
      • On the WSUS server, run in an elevated PowerShell window:
             $server = Get-WsusServer
             $config = $server.GetConfiguration()
             $config.MUUrl
      • Ensure the endpoint is https://sws.update.microsoft.com. If it is https://sws1.update.microsoft.com or https://fe2.update.microsoft.com, switch to the new endpoint as described in the WSUS synchronization guidance.
      • If synchronization fails with errors like “The client and server cannot communicate, because they do not possess a common algorithm,” follow the TLS/cipher guidance in the WSUS sync troubleshooting article.
    6. Review WSyncMgr.log and WCM.log on the site server
      • Correlate the SoftwareDistribution.log errors with WSyncMgr.log/WCM.log to confirm whether failures are due to WSUS health, connectivity, or EULA/content issues.
    If after these steps WSUS health checks pass, WSUS can synchronize successfully with Microsoft Update, and EULAs/content are downloading correctly, retry a SUP synchronization in MECM. Any remaining errors in SoftwareDistribution.log and WSyncMgr.log will then more clearly indicate whether specific updates or categories are problematic.
