how to make a wireless output have sound
Mmethi Prosperity 0 Reputation points
2026-05-24T10:06:54.9066667+00:00
When i try to connect my tv wireless,it doesn't show that it has sound.How do i enable it?
Windows for home | Windows 10 | PC projection
  1. Ivan B 127.3K Reputation points Independent Advisor
    2026-05-24T11:00:51.29+00:00
    Hi ,
    Search for msinfo32.exe in the search bar, take a screenshot, and post it here so we can see the correct laptop model or desktop configuration.
    Open the command prompt (admin) and run the commands: sfc /scannow and dism /online /cleanup-image /restorehealth, wait for the process to finish and restart the computer.
    Thanks
  2. Usario Usario 10 Reputation points
    2026-05-24T10:44:35.2433333+00:00
    Usually this happens when the TV is connected for display only but the audio output isn’t switched automatically.
    First check your sound output on the PC: go to Sound Settings → Output device and see if your TV/“Wireless Display” is selected. Sometimes Windows keeps audio on speakers/headphones instead of switching to the TV.
    Also, disconnect and reconnect the wireless display (Cast/Project), and restart both devices. In some cases, updating your graphics + audio drivers also fixes the missing sound issue.
    If possible, check the TV settings too—some TVs have a separate option to enable audio for screen mirroring.
