A family of Microsoft products that enable users to capture, organize, and reuse notes electronically.
Hi @美花 小,
Thank you for providing a detailed account of the troubleshooting steps you have already performed.
As you shared, OneNote is failing to load or synchronize your notebooks on your Samsung Tab 10 FE+, despite performing clean reinstalls, clearing cache and data, and verifying that the application functions correctly on other mobile devices.
This behavior is currently an issue resulting from a WebView regression within the Samsung April 2026 security update. To help resolve this, please follow the specific sequence below:
Step 1: Try to reset Android System WebView
- Navigate to Settings > Search for "Android System WebView" > App Details in Store > Remove Updates.
- Reboot your device.
- Return to Settings > Search for "Android System WebView" > App Details In Store > Update.
Note: If "Android System WebView" does not appear in your primary app list, please navigate to
- Settings > Google > All services > System Services > Select "Android System WebView."
- Reboot the device once more.
- Launch Teams or Outlook and attempt to log in to re-establish the authentication handshake.
Step 2: Update Google Play system.
Please ensure your core system components are current, as these manage security certificates:
- Go to Settings > About tablet > Software information.
- Tap Google Play system update and install any available patches.
Step 3: Service Verification via Web.
To isolate the device from the account, please sign in to onenote.com via a web browser. If your notes appear correctly there, the issue is strictly localized to the tablet's application environment.
Note: As you are using an education account, and this service disruption is widespread this month, I recommend contacting your institution's IT department. They should investigate if specific Microsoft Entra ID (formerly Azure AD) conditional access policies were inadvertently triggered by the latest Samsung firmware update.
I hope the information above is helpful. Please let me know if the behavior persists after following these procedures.
Looking forward to your update.
