Issue with Lab instance ID: 60532422
Josh Lear 20 Reputation points
2026-04-03T19:28:47.03+00:00
Hi, I’m blocked on an assessment because the environment does not match the instructions.
The task says: “The Azure OpenAI service has already been deployed to the RG1lod60532422 resource group.”
But when I open resource group RG1lod60532422, it is empty and shows no resources.
I also checked IAM and my account appears to have reader-level access only, so I’m unable to create the missing Azure OpenAI resource or assign permissions myself.
Because of that, I can’t complete the task as written.
Can you please verify or reprovision the assessment environment, or confirm whether the Azure OpenAI resource was supposed to already exist in that resource group?
Thanks.
Azure Lab Services
Azure Lab Services
An Azure service that is used to set up labs for classrooms, trials, development and testing, and other scenarios.
Julian Sharp 48,061 Reputation points
2026-04-03T21:41:42.61+00:00
1 additional answer
    2026-04-03T19:28:56.1533333+00:00
    The lab environment and its resources are provisioned and managed by the lab provider; resource groups and services inside that environment cannot be fixed or recreated directly from the Azure portal when only Reader access is available.
    If the resource group RG1lod60532422 is empty even though the assessment instructions state that an Azure OpenAI resource should already exist, this indicates a lab provisioning issue that must be resolved by the lab owner/instructor or the platform support team.
    Recommended next steps:
    1. Share the exact lab instance ID 60532422, the resource group name RG1lod60532422, and the symptom (empty resource group, Reader-only access) with the lab owner or instructor.
    2. Ask them to verify the lab plan and template configuration and, if necessary, reprovision or reset the lab VM/session so that the Azure OpenAI resource is deployed as described in the instructions.
    3. If they confirm the template is correct but the environment still provisions incorrectly, they should open a support request for Azure Lab Services with the lab plan details and your lab instance ID so the backend environment can be investigated.
    The error message pattern described in the Lab Services documentation shows that permission and provisioning issues are handled at the resource group or subscription level by an administrator, not by the learner. Similarly, assigning roles such as Lab Creator or fixing missing resources requires someone with higher-level access on the lab’s resource group or subscription.
