How to Fix a Namespace Mismatch
RogerSchlueter-7899 1,781 Reputation points
2026-03-30T21:42:54.38+00:00
In my application named PIM I just use the default namespace "PIM" to include everything. However, I do have one folder called "Converters" that includes numerous all the project converters. However, for some reason, the compiler says it can't find them. I've tried several different schemes to tell the compiler where they are to no avail. How can I do that?
Developer technologies | Windows Presentation Foundation
Jack Dang (WICLOUD CORPORATION) 18,975 Reputation points Microsoft External Staff Moderator
2026-03-31T03:12:33.7933333+00:00
Hi @RogerSchlueter-7899 ,
Thanks for reaching out.
In C#, the compiler does not use the folder structure to locate classes, it relies on the namespace declared inside each file. So even if your converters are inside a Converters folder, what matters is the namespace at the top of those files.
For example, your converter files should look like:
namespace PIM.Converters
    public class MyConverter
        // code
A few things to check:
  1. Namespace must match how you reference it:
If your files are declared under namespace PIM, then referencing PIM.Converters will not work. Make sure the declared namespace matches exactly what you’re using.
  1. WPF / XAML usage:
If you’re using these converters in XAML, ensure the namespace is mapped correctly:
xmlns:conv="clr-namespace:PIM.Converters"
Then used like:
<conv:MyConverter />
If the namespace here doesn’t match the C# file exactly, XAML won’t resolve it.
  1. Class accessibility:
Make sure your converter classes are marked as public. Otherwise, they won’t be accessible from XAML or other parts of the project.
  1. Spelling and exact matches:
C# is case-sensitive. Even small differences will cause resolution failures.
  1. Different project/assembly:
If your converters are in a different project/assembly, update the XAML namespace like this:
xmlns:conv="clr-namespace:PIM.Converters;assembly=YourAssemblyName"
  1. General checks:
  • Rebuild the solution
  • Ensure the files are included in the project
  • Watch for duplicate or conflicting type names
Hope this helps! If my answer was helpful, I would greatly appreciate it if you could follow the instructions here so others with the same problem can benefit as well.
1 additional answer
    2026-03-30T21:43:05.4033333+00:00
    In a .NET project, folders do not define namespaces; only the namespace declarations in code and the project’s default/root namespace do. If types in the Converters folder can’t be found, the namespace in those files likely doesn’t match how they’re being referenced.
    Use these steps to fix the mismatch:
    1. Open one of the converter files in the Converters folder.
    2. Check the namespace at the top of the file. For example, it might look like:
             public class MyConverter { ... }
    3. Ensure that:
      • The project’s default namespace is PIM (Project Properties → Application → Default namespace in older project types, or the root namespace implied by the project name in SDK-style projects).
      • All converter classes in that folder use a consistent namespace, such as PIM.Converters.
    4. In code or XAML, reference the types using that namespace:
      • In C#:
             using PIM.Converters;
             // Now MyConverter is visible
      • In XAML (for WPF):
    5. If there are any using/Imports or alias conflicts, resolve them by:
      • Removing or correcting incorrect using/Imports that point to non-existent namespaces.
      • Ensuring there is no conflicting alias or type with the same name as the namespace, as naming conflicts can cause ambiguous or unresolved references.
    If the compiler reports that a namespace or type in an Imports/using or project-level imports cannot be found or has no public members, verify that:
    • The namespace is spelled exactly as declared in the code files.
    • The types in that namespace are public.
    • Any project or file-level imports/using directives do not reuse aliases or conflict with type names.
