Probleme avec small basic
gilles leroux 0 Reputation points
2026-02-02T15:59:00.81+00:00
Avec small basic mon programme marche 1 fois puis bug ensuite
merci de m'apporter votre aide
Developer technologies | Small BASIC
A programming language created by Microsoft that serves a stepping stone for beginners from block-based coding languages to more complex text-based languages.
    2026-02-02T15:59:11.64+00:00
    It seems like you are experiencing issues with your Small Basic program where it runs successfully once but encounters bugs afterward. Here are a few general troubleshooting steps you can take to identify and fix the problem:
    1. Check for Errors: Look for any error messages that appear after the first run. These can give you clues about what might be going wrong.
    2. Review Your Code: Make sure there are no logical errors in your code that could cause it to behave unexpectedly after the first execution.
    3. Reset State: Ensure that any variables or states are reset properly before each run. Sometimes, leftover data from a previous execution can cause issues.
    4. Debugging: Use debugging techniques to step through your code and observe where it might be failing. You can use breakpoints to pause execution and inspect variable values.
    5. Simplify Your Code: If possible, simplify your code to isolate the part that is causing the issue. This can help you identify the specific line or function that is problematic.
    If you continue to have issues, consider seeking help from communities or forums dedicated to Small Basic, where you can share your code and get more specific advice.
