How to automate browser tasks using Python without getting detected?
john conner 0 Reputation points
2026-02-02T06:33:42.5933333+00:00
I want to create a Python script that can automate repetitive browser tasks like filling forms and clicking buttons.
My Requirements:
  • Need to run automation on multiple tabs
  • Should work with Chrome browser
  • Should not get detected by websites
What I need help with:
  • Which Python library is best - Selenium or Playwright?
  • How to make my automation look like a real user?
  • How to handle browser fingerprinting issues?
My Experience Level:
Beginner in Python automation
Any suggestions or code examples would be helpful!
Developer technologies | Visual Studio | Testing
    2026-02-02T06:33:56.0066667+00:00
    To automate browser tasks using Python, you can use either Selenium or Playwright, both of which are popular libraries for browser automation. Here’s a brief overview of both:
    1. Selenium: A well-established tool for web automation that supports multiple browsers including Chrome. It allows you to control the browser through Python scripts and can handle multiple tabs.
    2. Playwright: A newer library that offers more modern features and better support for handling multiple browser contexts and tabs. It also provides capabilities for automating interactions in a way that can mimic real user behavior more closely.
    Recommendations:
    • Best Library: Given your requirements, Playwright might be the better choice as it is designed to handle multiple tabs and contexts more efficiently and has features that help avoid detection.
    Making Automation Look Like a Real User:
    To make your automation appear more like a real user, consider the following strategies:
    • Randomize Actions: Introduce random delays between actions (like clicking and typing) to mimic human behavior.
    • Use Realistic User Agents: Change the user agent string to reflect a real browser user. Both Selenium and Playwright allow you to set custom user agents.
    • Mouse Movements: Simulate realistic mouse movements instead of jumping directly to elements.
    Handling Browser Fingerprinting Issues:
    • Headless Mode: While running in headless mode can be faster, it can also trigger detection. Consider running in a non-headless mode.
    • Browser Profiles: Use browser profiles that have cookies and cache to make the session look more authentic.
    • Avoid Common Patterns: Avoid predictable patterns in your automation scripts that could be flagged by anti-bot systems.
    Example Code Snippet (Using Playwright):
    Here's a simple example of how to set up Playwright for automation:
    from playwright.sync_api import sync_playwright
    with sync_playwright() as p:
        browser = p.chromium.launch(headless=False)
        context = browser.new_context()
        page = context.new_page()
        page.goto('https://example.com')
        page.fill('input[name="username"]', 'your_username')
        page.fill('input[name="password"]', 'your_password')
        page.click('button[type="submit"]')
        # Add more actions here
        browser.close()
    This script launches a Chrome browser, navigates to a website, fills in a form, and submits it. You can expand this by adding more interactions as needed.
    Make sure to test your automation thoroughly to ensure it behaves like a real user and adheres to the website's terms of service.
